sbrown.nw's Avatar
Any picts with < 89 cars with round valence fog lights?
Thinking of going with some round ones mounted in the lower valence instead of the factory rectangle. Wonder what they look like if anyone has done this.
TIA,
Scott
72 911 T Targa in Orient Red / Black - more like a 85 Euro RS IROC now
- 85 Euro 3.2 with x-faktory EFI ITB + SSI + Dansk, 915 + Wevo, flares + IROC bumpers + duck tail, RS door panels, Corbeau LG1 microsuede seats, Speedware harness bar + drop links + Scroth DOT harnesses, adj Tarett sways, sport shocks, alloy trailing arms, Elephant Racing oil lines + spring plates + bushings, RSR Rota Foxes + Bridgestone S-04 PP, 2450 lbs
Old 06-01-2008, 01:44 PM
sbrown.nw's Avatar
anyone?
Old 06-06-2008, 10:30 AM
Diss Member
Quicksilver's Avatar
Here is what I have done with mine...
I personally don't like the rectangular lights on a beautiful rounded car. To make the projector (or any other) lights really work aesthetically I think you would need fab up a fairing to fit between the rectangular hole and the round lights. If you were really slick you could make it also act as an air duct for the brakes. I originally was intending to do this but the project ran out of steam.
If (when) I stick my nose back in this project my direction is going to be a RUF Yellowbird styled valance using the oval Hella FreeForm lights mounted in a custom opening that will also act as the brake ducts.
The smaller Hella FreeForm ovals will fit the stock rectangular valance hole and I think they would look very nice with a clean fairing to integrate it into the body. (You would have to create a custom mounting bracket because their bracket is too big for the available area.)
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 06-07-2008, 03:55 AM
old man neri's Avatar
How did you mount those big round ones? I have been looking for a way to temporarily mount big powerful lights for those 1000+mi night trips through moose country.
Old 06-07-2008, 04:43 AM
[/I])
I am thinking of some additional lighting. I am wondering about using the holes where the licence plate used to be. Those smaller oval Hella lights might do the trick.
Old 06-07-2008, 10:23 AM
Diss Member
Grew up in moose country. Aircraft landing lights saved me more then once! (Saw the reflection off his eyeball about a mile and a half off!)
The big ones are KC Highlites Slimlights. (Cheap at JC Whitney) They are mounted to a 1-1/4"x1/4" flat bar stock that is welded to another section of the same stock so it forms kind of a Z bend. It bolts to the side of the main tub with 2 bolts and the outer offset part extends through the stock foglight hole. You can remove them and no one will know that they were ever there.
You have to use a very thin light because of how low they are. The bumper extends out further then the light, and if you scrape the ground the lights will rotate to avoid breaking. You also have to drill a new drain hole at the bottom of the light housings as they were intended to be mounted at the bottom.
They throw out a bunch of light but they would work better if they were mounted higher. If I was running moose country I would probably rig up something that was above the bumper. It had occurred to me that you could build a light mount bar that would attach to each of the headlight rings. That could make it easy to remove. (Have to work out the whole hood opening thing...)
Old 06-07-2008, 10:41 AM
sbrown.nw's Avatar
Here are the valence lights I went with:
Old 11-17-2008, 08:46 AM
m110's Avatar
Not exactly what you meant but I think round lights recessed with a flush plexiglass cover would allow you to get a decent reflector and size and not have it stick out on the outer lower edge.
1988 Carrera Coupe
Old 11-17-2008, 09:37 AM
Model Citizen
herr_oberst's Avatar
[/QUOTE]
that is just freaking pornography . . . .
Old 11-17-2008, 10:07 AM
Ai, it is a bit much... It makes ones eyes water! It just about hurts
Old 11-17-2008, 11:33 AM
I did cutouts for the oil cooler on my SC.
Ray
'88 Carrera, '81 SC, BMW R1200C, BMW R75/5, Ducati S2R Monster, '70 Karmann Ghia
Old 11-17-2008, 01:27 PM
4flyboy's Avatar
That SC is sweet..............
S.
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 11-17-2008, 01:42 PM
Thnx....
Ray
Old 11-18-2008, 02:18 AM
BoxsterGT's Avatar
Porsche Crest
Damon, where are you?
We need you for these fairings.
Old 11-18-2008, 03:27 AM
m110's Avatar
Not my car but a great look from another thread
1988 Carrera Coupe
Old 11-22-2008, 09:25 AM
Uncle Enzo's Avatar
Brining this back. I'm looking to drop some 6in round hallas up front under the bumper and was looking for any pics you fellas might have.
1976 911S
MidYear Fever is alive and well.
Old 02-06-2015, 11:39 AM
sbrown.nw's Avatar
My car looks so different now
Old 02-06-2015, 11:46 AM
sbrown.nw's Avatar
These are the lights I used:
http://www.amazon.com/gp/product/B000BNU1IM/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
Old 02-06-2015, 11:49 AM
Uncle Enzo's Avatar
Wow..nice transformation!
1976 911S
Old 02-06-2015, 11:57 AM
Look in this thread:
934 spoiler for 930's
Emery
1988 930 coupe - Silver Metallic
TurboKraft 3.3L 8:1 CR, SuperSC Cams, GT35R, B&B Headers, TK intercooler, Tial WG, ARP, tecGT based phased sequential EFI & ignition, Wevo shifter/coupler, ...
Old 02-06-2015, 01:32 PM
