911 carrera 3.2 (1985)
kees's Avatar
Porsche Crest Bracket ambient air valve
In the progress of installing a new ambient air valve (n0. 31), new hoses and a new bracket (no. 32).
Can somebody please tell me the partnumber(s) of the nut/washer to mount the bracket...can't find it in PET.
Thanks,
Kees
Old 02-05-2018, 04:27 AM
On an 88, it goes on the upper rear oil tank mounting stud. Slide it on before attaching the nut. I'm assuming same for 84-86.
Old 02-05-2018, 05:59 AM
kees's Avatar
Porsche Crest
Unfortunately it's not for a '85. There's some kind of welded bolt on the right side near the oil filler neck.
I thought it was a M8 nylock nut, but it isn't.
When I am at home I will take a picture.
Thanks!
Old 02-07-2018, 12:54 AM
kees's Avatar
Porsche Crest
Old 02-07-2018, 07:53 AM
That sure looks to me like one of the oil tank mounting studs. Same washer. It should take an M8 nut. Not sure why it doesn't. Are the threads maybe messed up on the end?
_______________
John
1988 Carrera Targa 3.2 G50 - Sold.
2017 Chevy Silverado K1500.
Old 02-07-2018, 08:13 AM
kees's Avatar
Porsche Crest
Hi John,
Thanks for your reply. You are right; it does take a M8 nut. But there is one thing I don't understand. The original nut needed a 14 mm socket, the new M8 (Porsche) nut a 13 mm socket. Inner diameter is the same, but the original nut is bigger (see pic).
Kees.
Old 02-07-2018, 09:03 AM
That I'm not sure about. But I suspect either should work!
_______________
John
Old 02-07-2018, 09:32 AM
kees's Avatar
Porsche Crest
Thanks John,
All is clear now. You were absolutely right on the oil tank mounting studs. Didn't understand it at first (English is not my native language), but now I see what you meant.
Searched in PET for the oil tank and found the partnumber for the nut. It's a M8 nut, but it takes a 14 mm socket.
Thank you very much.
Kees.
Old 02-08-2018, 02:47 AM
