-   -   Need Help with 3.2 Engine Harness (http://forums.pelicanparts.com/porsche-911-technical-forum/986945-need-help-3-2-engine-harness.html)
Gulf91474 02-08-2018 05:04 AM
Can someone tell me what this connector would attach to? I've isolated everything else. this is on a 3.2 engines wiring harness. http://forums.pelicanparts.com/uploa...1518098557.jpg
Thanks for the Help...
old man neri 02-08-2018 05:31 AM
Could you take a better picture? One that shows what the mating surface of the connector looks like? Also, is it two or three wires? It's hard to tell if one of those wires is for that spade connector underneath.
Gulf91474 02-08-2018 05:56 AM
Sorry about the pic. 3 wires going into the connector, black / black/purple / yellow..
cant get another pic till Friday.
ppetion 02-08-2018 06:28 AM
02 sensor?
76FJ55 02-08-2018 06:41 AM
Looks to be the connector the connects the DME to the dash assembly. Yellow connects DME pin 4 to Ignition starter switch pin 50, Black and Black/Violet connect DME to Tach. Black goes DME pin 11 to Tach pin 1 and Bk/Vi goes DME pin 21 to Tach pin 2. From factory wiring diagram: I think you are looking at connector Item # 59 which is located on diagram page 6 in grid F33.
Gulf91474 02-08-2018 06:48 AM
Awesome. Thanks for the info....
