CV joint gaskets
My 110mm CV use a gasket between the CV joint and the out put flange but I cant find the 100mm version. Anyone know the part number?
Thanks David |
I'm looking for # 19 in the diagram below except for the 100mm flanges. This is the PET for up to 1977
Here is the PET for the 1978-1983. I know that I don't want the turbo part but do I want the 901 or the 923 part
You should have 4 10 mm bolts and 2 roll pins
The bolts and pins are inside the seal so part #19 should work, The 923 part is the 912E which is probably 8mm bolts Bruce Last edited by Flat6pac; 09-05-2020 at 04:43 PM.. |
I have switched to the 6 bolts (M8) due to adding a ZF limited slip differential.
Use the CV joints with caps on them. No gasket required. I use a little non hardening sealant inside the cap around the perimeter and bolt holes.
72 Carrera RS replica, Spec 911 racer |
Yes, that will work for the inside of the CV joint but what about where the CV bolts to the trans or hub flange?
Eagle is talking about the mid 85 and later
They are 10 mm bolt up on the trans, won’t work for 77 and SC trans flanges The 8 mm bolt up uses S.C. cv gaskets with the bolts outside the seal. Bruce |
CV joint gasket
I have 2 new gaskets for 108mm CV. I can send them if you want.
1984 911 Carrera Coupe - 32C #73 - M64/05 1998 E36 M3 4dr 2006 Sienna 5dr - the hauler 2004 Lexus GX470 2010 Cannondale Caffeine II - Lefty |
Thanks for the offer but I have ordered them already
