Question 72 911
Did these cars have an oil level indication?
Bruce
Old 02-18-2003, 07:37 AM
Send a message via AIM to Oldporsche
Yes
Good luck,
David Duffield
have owned/driven more than one Porsche
Old 02-18-2003, 07:42 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
Are you asking about the one on your dashboard? I think some do and some don't. In my '73 manual it shows that there is for some E's and T's
I think all S's had the oil level indicater.
Don't go by the oil level indicater, it's not very accurate. Use the dipstick on level ground, on a warm idling engine.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 02-18-2003, 07:44 AM
Send a message via Yahoo to RichMason
I agree with Tim that the oil level indicator is not the first choice for determining when you need oil. However, once you figure out where the guage rests when you have the correct level in your car, it is a good substitute for the dipstick.
Rich Mason
87 951 for sale $5500
Old 02-18-2003, 07:51 AM
i have a t with a s instrument/trim option. might have been an option on t's.
72 911t grey/black mine
74 914 2.0 black/ tan hers
02 g500 black/black womanproof
01 f250 psd dirty the mule
60 correct craft starflite cool
69 correct craft torino hauls butt
72 correct craft ski nautique fun
66 vw 1500s will finish someday
Old 02-18-2003, 08:15 AM
Thanks guys. I ask because I was looking at a parts diagram for the 72 and I didn't see a level sender as part of the diagram. I'm doing a project where I think the 72 oil tank will work well but I want the level, only because I want the gauge to work. As you pointed out I won't rely on it but I do want it functional.
Bruce
Old 02-18-2003, 09:04 AM
pwd72s's Avatar
Tryan nailed it...the optional on all models "S" gauge package contains the oil level gauge. Pretty well useless unless you read it under the same conditions you need to check with the dipstick. That is, car sitting level, temp above 180 degrees, engine revs at idle. For your project, it would be easiest to get the oil tank from a car that had the "S" gauges...
Old 02-18-2003, 11:56 AM
