-   -   Replacing oil pressure sending unit: torque spec (http://forums.pelicanparts.com/porsche-911-technical-forum/987238-replacing-oil-pressure-sending-unit-torque-spec.html)
OldSpool87 02-11-2018 04:54 AM
Mods- please delete. Duplicate thread.
They only torque spec I can find is in the Bentley for the “sending unit to case” at 26 ft-lbs. I assume this is for the through bolt.
I took the sending unit off with the mounting block and have it relaxing in some Kroil. Are there specifIc torque settings for the banjo bolt at the tensioner I loosened?
Or is this a snug up and snug some more if needed type operation?
Thanks,
Will
