901/03 sealing ring p/n
I have a 901/03 transmission and I canít figure out through PET or this site the proper p/n for the drive shaft sealing rings. I believe it to be 999 113 058 50, can anyone confirm.
Old 02-11-2018, 10:52 AM
Just bumping due to forum being down.
Old 02-12-2018, 04:03 PM
Red Line Service
Marc Bixen's Avatar
901/03 is not a good number. Double check 901/02,901/13???
Marc Bixen
Red Line Service
West Los Angeles, Ca.
Old 02-12-2018, 06:22 PM
Well the number disappeared with road scars but the s/n is fully visible and is 2280944
Old 02-13-2018, 03:31 AM
Marc, your post made me think and I think I have this partially figured out. 901/03 is a 68 T gearbox available in R.O.W., Iím in Canada. This also explains why itís not listed in my U.S. downloaded PET catalogue. Does anyone have a R.O.W. PET that can validate the sealing rings, it must be the same as a 68 L gearbox I would think.
Old 02-13-2018, 03:56 AM
djpateman's Avatar
It certainly is a valid type #. All aluminum case trans should use the same seal ring.
Keeper of 911, 912 & 914 databases Kardex source
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 02-13-2018, 05:54 AM
Dave, would you have type number of the aluminum 5 speed regular trans 68. The only difference I see in PET is one seal is 45x68x10 and the other 45x65x10, I believe these measurements to be I.D., O.D., and thickness. I can hopefully measure the O.D. Tonight and see if I get 65mm or 68.
Old 02-13-2018, 06:57 AM
Norm, as I already explained on your other thread, you have a 1968 911T 5-speed transmission with simplified differential, type 901/03.
Your other thread: Identify transmission
All transmissions for model year 68, including Sportomatics, had aluminum housings and used the same axle flange oil seal.
Seal number 999.113.058.50, size 45 x 65 x 10 mm.
Jon B.
Vista, CA
Old 02-13-2018, 10:42 AM
Thanks Jon, yes you did reply that it was a 901/03 and I appreciate that but I couldn’t find a reference to the seal in PET for that transmission. Measured it tonight and you are right, it’s a 65mm. Thanks for your help.
Old 02-13-2018, 03:21 PM
Red Line Service
Marc Bixen's Avatar
Sorry about the mistake, I was going by Porsches new "electronic" information. Just goes to show, you can't beat the old spec book. Thanks Jon.
Marc Bixen
Red Line Service
Old 02-13-2018, 05:51 PM
No problem, Marc :-)
Since the 68T was a non-US ROW model, sometimes it wasn't included in US-specific references.
Type 901/03 was a 1-year (68) transmission.
I still refer to the old factory paper manuals for information.
Jon B.
Vista, CA
Old 02-14-2018, 07:08 PM
To get ROW PETs use the Porsche website and choose any region except North America USA.
Then choose Services & Accessories, Classic, Genuine Parts Catalogue.
This is the Malaysia web page: Porsche Classic Genuine Parts Catalogue
Use the pull down menus to pic your specific Model and Year.
Old 02-14-2018, 09:09 PM
