2.7 cam timing
First off, thanks to those who replied to my previous thread. I now have a set of 2.7 Carrera cams #143 &144. Does anyone have the timing specs to set up these cams? My dial indicator is imperial, not metric. I'll do the conversion if needed. Thanks, Craig.
I usually refer to spec book but from Wayne’s... 0.40-0.54mm at overlap TDC with 0.1mm valve clearance.
| All times are GMT -8. The time now is 10:21 AM. |
