Looking for Service Bulletin Nr. F 4/67
The bulletin Nr. F 4/67 had as an attachment the
"Einbauanleitung zum nachträglichen Einbau eines hinteren Stabilisators" - "Installation instructions for retrofitting a rear stabilizer" There are two pages, plus one sketch in scale 1:1 plus a template for correct work and drilling. If anyone could scan it as a PDF I would greatly appreciate it. Thanks in advance. Chuck |
I presume this is for adding a rear sway bar.
If so, Weltmeister has a product that will allow you to mount the rear sway bar via the torsion bar tube. I have this on my car and it works fine. https://www.pelicanparts.com/More_Info/SB2900.htm?pn=SB-2900&SVSVSI=5878
Under the radar
Not sure what car you have but my '71 did not come with sways. I fabbed the right rear mount and welded it on. Not hard to do if you have basic welding skills. The drivers side was already there. Someone used to sell weldon mounts. Wevo?
This bulletin gives measurements for drilling the ball pens into the trailing arms. I just want to get the ball pens as close as possible to stock.
Thanks |
Free will is doing what we must joyfully. Jung '68 912 Coupe '82 SC sunroof |
