Need help with tire size
I recently picked up some Borbet 964 Cup wheels on the cheap. 17x9 rears and 17x7 fronts.
I have an '87 911 I'm looking to mount them on. I have an aftermarket widebody kit. Currently have 16x10 BBS and 2" spacer in the rear and 16x8 w/ 1" spacer in the front. Fronts run 225/55/16, rears are I believe 245/50/16. Much more tire options with 17" but want to make sure I nail the fitment. I used to have 3" spacer in the rear but I sold them. I lose some width in the back so perhaps getting 3" spacer in back I can go with 245s. Not sure on the fronts. Any suggestions? Tires will be for mostly summer driving (I'm in Omaha so car does get on the road Dec-Feb) and the occasional track day. Currently have Toyo Proxes on there. Thanks! |
Also are you happy w/ the old fitment in terms of where the tire sits relative to the fender lips? |
Offsets on new ones are 47 in the rear and 55 in the fronts I believe. |
the new are 964 fitment w/ high ET, that means larger than usual spacers will be needed |
Ok, so I measured these out and test fit them.
The rear BBS I had on where offset of 23 vs new ones which are 9 wide instead of 10 but offset of 47 so when I put them on it actually looked pretty decent. I could maybe use another inch (too bad I sold my 3" spacers, have 2 on there now). Fronts look pretty good too. Currents were 28 offsets. Question is how wide of a tire can I put on these? I currently have 245s on the rear 10s which I could probably go wider but hard to find wider on a 16. 17" wheel should give me more options. Fronts have 225s on them. Thoughts? |
Ona 9 you could go to 265/40. The issue is retaining f/r balance and keeping tire od down. The most common 7 & 9 fitment is 225/45 & 255/40 |
Dredging up this old post. I found a deal on some Sumitomo rears 255/45/17 that I picked up. If I go with these and 225/45/17 is that gonna really throw everything off? I know I'm trying to match ride height closely. Maybe a 225/50/17?
Original rear tire size Pirelli P Zero Rosso N4 overall diameter, per Tire Rack:
245/45ZR16 - 24.6" 225/50ZR16 - 24.9" They list the Sumitomo HTR Z II 255/45ZR17 with an overall diameter as 26.4". For me that would be too far off from the factory diameter. The 245/40ZR17 would be a better choice with diameter 24.8". |
Here are the Summis that pair well, you want them to be in agreement on the X axis and staggered on the y, the more motor the more stagger.
http://forums.pelicanparts.com/uploa...1542652480.gif |
Pretty clear I need 225/45/17 for my fronts and looks like 244/45/17 don't pair up well with those. Honestly thought i was buying 255/40s until I picked them up. |
| All times are GMT -8. The time now is 04:55 AM. |
