-   -   Turn signal (http://forums.pelicanparts.com/porsche-911-technical-forum/987838-turn-signal.html)
macssc911 02-16-2018 12:45 PM
Turn signal
Hey guys all turn signals work fine on outside of car but indicator lights in tach don’t, bulbs ok the right bulb will flash on for a second but stops working . Would this possibly be the hazard signal relay or something else
Thanks Mac
proporsche 02-16-2018 12:58 PM
hi..yes it is possible your relay is not good.also check the ground wire to that gauge.
Ivan
universeman 02-16-2018 06:54 PM
Could be ground on that gauge. Or light bulb could have fallen loose from the socket.
If flashers externally work, relay is fine.
