APB - I知 Stuck - Rear Brake Job today
How do you get the bottom 19mm bolt off the caliper, so I can remove the caliper and change the rotor? Top one is easy to get a wrench on. I dont seem to own a wrench to get to the lower bolt? Pelican tech article had this question asked, and no one answered, searched here, youtube, etc....nada. I am sure there is a trick. It’s on my ‘75 911 widebody.
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
More fiddling and I answered my question. I needed a 3/8 drive short 19mm socket and a thin headed socket wrench....then tap with a hammer to break free. Let’s hope there is no more to come here today.
19 mm box end and take your time
Bruce |
I used one of these:
1982 911 Targa, 3.0L ROW with Webers |
Registered Minimalist
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
just seeing this - yeah, one of the suckiest bolts to work on - I think there should be a badge or major karmic reward in your future.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Well I got the brakes all done today. I took a ton of pics (including how to get to this bolt) with the hopes of doing a “how to” thread. I will see if I can get it written tomorrow.
Where does everyone host their pictures to post? I have been a PBase user for ages...but they are getting a little long in the tooth. Pondering a change.
Yep,
Long handle box 19 to break loose and then open end with a lot of turns . . . But, if you leave the top bolt tight you might be able to finger out the bottom after a few turns of the box . . . Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine |
