Tool Identification #2
A few more for your viewing pleasure
Please help me ID these #1http://forums.pelicanparts.com/uploa...1519081528.jpg http://forums.pelicanparts.com/uploa...1519081551.jpg #2 http://forums.pelicanparts.com/uploa...1519081614.jpg #3 http://forums.pelicanparts.com/uploa...1519081656.jpg #4 http://forums.pelicanparts.com/uploa...1519081683.jpg http://forums.pelicanparts.com/uploa...1519081704.jpg http://forums.pelicanparts.com/uploa...1519081724.jpg #5 http://forums.pelicanparts.com/uploa...1519081755.jpg http://forums.pelicanparts.com/uploa...1519081770.jpg |
No 2. Allows you to take a sledge hammer "persuader" to go after large axle bolt. I've seen them sold for VWs.
I still have mine. SmileWavy |
the mini slide hammer in #3 looks like a door hinge pin remover.
Lorne M. |
The second tool from the bottom in #3 looks to be a clutch pilot bearing removal tool.
#3 is basically a socket. You put the hex on a nut and a 1/2 breaker bar in the square hole.
My VW brake drum persuader doesn't look quite like that if I'm seeing it right. Which end are we looking at in that picture? Is the open end threaded to go on the axle? Seems way too small for that from the picture. |
| All times are GMT -8. The time now is 06:59 AM. |
