Fred Cook, I had a device on my 85 vw GTI track car that if I can remember correctly
had a wiring harness that would read my tach output and another connection inline with the "fifth injector" (cold start) to turn it on at an adjustable RPM for the same purposes you mentioned. I think it was something like Accutune or something to that effect. I had it mounted in the glovebox and it had a dial for adjustments. Terry |
Who knows, maybe a 4 cylinder is more tolerant of reversion than a 6. It is more of an academic curiosity, not advocating anyone try it. I wonder if there was a race class where cams were free but induction must remain stock, how far people would be willing to take it. |
The CSV does work when starting the engine. Yes, I used the stock aluminum distribution box and runners that are built into the air box. The seasonal changes amount to just adjusting the fuel mixture slightly and adjusting the air correction screw. I have an a/f meter permanently installed in the car so the tuning aspect is quite easy. Just for the record, this engine is running 964 cams and Mahle pistons at 10.8:1 compression. |
It should, but..............
I had the wrong impression that you were referring to the pancake like appendages. |
CIS Primer from Jim's Basement Workshop as someone else has already mentioned.
911 CIS Primer - Introduction Porsche Factory Manual https://www.manualslib.com/manual/1101788/Porsche-911.html Bosch K-Jetronic Workshop Manual http://www.type17.ch/downloads/Injection/Bosch%20-%20K-Jet%20-%20Workshop%20Manual.pdf Bosch K-Jetronic Technical Instruction https://www.slideshare.net/guestceff35/bosch-k-jetronic-fuel-injection-manual I printed all that I could for when the world goes back to analog. These and the Bentley manual are my keys to the kingdom. And if you can manage to stay awake through it, this is also informative. https://www.youtube.com/watch?v=a4fJAfXYxWk Enjoy! |
Eliminate all air leaks and all stock settings snd the cis works. The turbos used it so it should be able to feed some high hp.
I have an 81 with CIS. A guy showed me his 79 GTI CIS system. It was "cute" compared to mine - just as mine is cute compared to the 930. Engine Builders Supply told me they had taken a 3.0 up to 4.0 and the stock CIS worked fine. Regular CIS, not the Carrera 3.0. Just one conversation though. |
| All times are GMT -8. The time now is 02:25 AM. |
