need help finding titanium springs
All,
I'm trying to find some place that sells lighter valve springs, but with the same strength. I found some places (Patrick Motorsports, TurboKraft, etc..) that sells the springs, but they are a higher strength. As I've been reading that a higher strength spring puts too much load on the cam and is only useful for engines running well above stock rpm limits, I was looking for something that provides a faster spring response to keep from floating valves, but not wear down the cam. Any suggestions? Thanks all for your help. |
didnt know anyore made titanium springs. They make titanium retainers and locks. My motor has the eibach high pressure springs and titanium retainers and locks from Xtreem.
How high are you planning to rev it?
You are confusing strength and stiffness. The stiffness of a spring, or spring rate, is a measure of the force required to compress the spring. Measured in lb/in or kg/mm. The strength is basically a measure of how much force it takes to break the part.
The Eibach 911 valve springs would suffice.
Ryan |
For what it's worth we've used the Aasco performance springs with Ti retainers on the track for years with no issues. This is with a 7k rpm limit and occasional over revs. After about 4 seasons of racing the cams had minor pitting on a couple of lobes.
What's a good place that sells highly reliable, lighter valves? |
The Eibach springs are indeed sufficient for your intended rpm range. As the other guys indicated, the AASCO spring & retainer kit is a good one too. Been a great choice for a long, long time. So is EBS Racing's VMax kit. Kibblewhite also makes a kit for the old 911
Racing Spring Kit, Titanium, 0.540" Lift, Porsche®, 2 Valve - 911/930/964,Â*| Kibblewhite Precision Machining, Inc But if you're not moving away from the 3.2 intake manifold, you're losing a TON of power and not able to take advantage of that increased rev limit. You also need to strongly consider stronger rods at that rpm level. The 3.3/3.3/3.6 rods are at their limit at 7000 rpm with ARP or Raceware bolts. Push them to 7500 all the time, especially a sustained duration like running to the top of 4th and into 5th at a track with a loooooooong straight and you're asking too much of those rods. If you go with titanium valves, I believe you need to use a valve guide made of different material than the standard guides are made of. Or is it the valve seat material in the head? I forget...... |
They said they would but would need a minimum order of 16 of each to justify the tooling set up. You might give Chris at turbocraft a call to see if he has any ideas, or see if anybody on the board wants to have some made. Patrick motorsports might be another place to check, they do retainers and keepers but no mention of valves. |
You don't need Ti springs... Get some valves with reduced diameter valve stems..valves that fit..Beehive springs.. and Ti retainers and keepers..
On top of that, I am going with some 3.4 p&c and having just about everything I can be ported & polished. Finally... I am going with 964 profile camshafts. But you also bring up a good point... my concern is that I don't want to mismatch parts and find that getting a stronger or lighter part means that I am stressing another component beyond its limits. |
We have a couple sets of the Eibach valve springs in stock if you want to go that direction.
| All times are GMT -8. The time now is 01:53 PM. |
