I called Mr Griffith and had a nice chat with him and went over what my car is and where I need to be to achieve the desired results that I want-I submitted his survey about my car and awaiting his feedback. will keep you posted
I installed mine over a weekend. Long dirty process, but well worth it. I highly recommend Griffiths.
I called Griffith's yesterday and received the data that I needed. I will go forward and purchase the system and a few options....On expectation management Griffiths was the only responsive and a lot of good feedback, good technical support and something that does not require a Phd from MIT to install...at this point I plan to do it myself.
I've got about 7 hours into it and ready to do all the hoses. But I had a lift and a couple of buddies helping. That doesn't include some prep work and reading the instructions.
I had my local independent install a full Griffiths package last year, including two condensers in the left rear fender well in my 79 Turbo.
Not cheap, but "When you buy quality, you only cry once." |
Why did you guys remove? Sent from my iPhone using Tapatalk Pro |
Blokhed
Sent you a PM Vince |
Griffiths complete unit in my 78 930. evaporator, condensers, hoses, extra condeser in the left wheel well, switches, extra under dash vents - everything! Excellent quality, great installation instructions, and a very clean look. Everything came very well packed - and was shipped fairly quickly.
I stronly recommend Griffiths for A/C |
It’ll be interesting to find out how the Classic Retrofit kit compares once it’s been installed and tested in southern cars. I like the idea of cleaning up the engine bay, but obviously the performance of the system is most important.
Full Griffith's back in 2008 on my 1988 Cab. Still going strong!
Don't get me wrong, the Classic Retrofit kit sounds very encouraging, but if you want a modern-performing AC system in an air-cooled Porsche (993s excluded), and you want it NOW, Griffith is the only way to go. |
Scroll compressors are highly reliable, more so than plate or piston types used in conventional engine driven units. It has no clutch either so is likely to outlast a standard AC compressor. By the time the compressor has failed we'll be using magneto caloric heat pumps for AC and heat anyway. That will give us a COP of 5 and will be another game changer. |
By bleeding edge, I would interpret that as your whole system, Johnny. There may be others using the same compressor, but the integration of that with the rest of your kit and our 911s is largely undocumented. As well, you are/were having your own sourcing issues which may possibly now be rectified.
I'm sure that in the end, Classic AC will turn out to be a great upgrade, but I have yet to read a single report from users here in North America. When there are sufficient users extolling its virtue in the heat and humidity soaked regions or the world, and the teething issues of mass utilization are solved, I expect the skeptics will quiet down. I'm personally holding off and waiting to hear some positive news from installations 'in the wild' before I decide which path I'll take. For a few months, anyway... |
| All times are GMT -8. The time now is 05:16 AM. |
