-   -   Swb 911 resistor and relay. (http://forums.pelicanparts.com/porsche-911-technical-forum/988961-swb-911-resistor-relay.html)
Lyndon302 02-26-2018 09:30 PM
I'm do the wiring properly before I give it a crank to see if it runs. This was on the rear left panel in the engine bay. ( what a mess ) .
Confirming this is the resistor relay ( can't read the Volkswagen part number) and the resistor to run a low voltage to the coil when running. I have an MSD ignition so these are now redundant. Correct.
Thabks Lyndonhttp://forums.pelicanparts.com/uploa...1519713038.jpg
