torque setting for condenser protective bar?
I want to take off my front condenser protective bar to clean it up a bit. I have a set of Rennline tow hooks up front that share a bolt. I don't have the Rennline instructions anymore. What torque should that bolt be done up to?
Car is a 1983 SC.
1983 911SC 2005 911S |
35 ft-lb per page 401-9 of the Bentley manual.
Thanks FJ! I only looked at page 870-6 in Bentley - where it refers to bolt 'B' - but doesn't provide the torque.
Do you reckon the protective bar adds useful stiffness to the suspension? I removed the condenser for weight reasons but I'm not sure whether I should also remove the bar...
I'm going to reinstall bar - mine just needs a sanding and painting.
