Turbo Powered Snow Blower
Auto Heat Controller Brown Wires
I decided to try and get the auto heat working.
First there are two brown wires that are not connected. They attach to the micro switch. One of them is broken off the switch. They do not show up in the 930 auto heat wiring diagram. I found a picture on the forum showing them connected to two yellow wires, but no info.
Are they for a different model car with the dual rear blowers? Pics below.
Second my external sensor is bad and while searching I found a post about an aftermarket replacement from DigiKey. But again no more info. Does anyone know the replacement part Iím looking for? Or a thread that lists it?
Pic of mine
Pic found with wires connected
Thank You,
Sent from my iPhone while Driving
Derrick
Old 02-28-2018, 07:23 PM
steely's Avatar
I can't answer the wiring question for your 79, but this thread contains a substitute part for the NLA sensor. It looks to be a thermistor (Honeywell) 121-102EAJ-Q01, and they run $20-30 online (mouser, Newark, etc)
edit: found $14 @ digikey
See post #3 from Gerry
3.2 Carrea cabin heater sensor cable replacement
HTH
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 02-28-2018, 09:42 PM
^^^ Thank you.
After some more searching I found a thread for the caloric sensor fix. Post 16 to the end are the best. $400.00 part for $2.00
Caloric Feeler
Derrick
Old 02-28-2018, 10:58 PM
I have the exact same wires, they are not connected on mine also, seems that they are not used on the turbo. I think they are meant for rear blowers that we do not have.
I made the same question in this thread. Auto heat Wiring
John
1979 930 - mahle 3.4 (7.5:1),Turbokraft longneck IC, Leask WUR w/rpm solenoid,sc cams, rarlyl8 headers, tial wg, 1 bar boost, GT35R
Old 03-01-2018, 12:46 AM
Thanks, So they are wires for the rear blowers. Which I don't have.
Mystery solved in four posts.
Derrick
Old 03-01-2018, 06:37 AM
steely's Avatar
Originally Posted by 1979-930 View Post
^^^ Thank you.
Caloric Feeler
That's even better.
A steal at twice the price! lol
Dan
Venetian Blue
Old 03-01-2018, 12:38 PM
T77911S's Avatar
i don't recall 2 brown wires not being connected when I did mine.
perhaps a better pic of what they ARE connected to.
here is my thread, probably more info than you will ever want.
I would just leave the resistor not connected.
auto heat- foot well blowers part deux.
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 03-02-2018, 04:20 AM
