Favourite Subject - Headers...
I read a lot about SSI is the way to go & GHL/B&B are way better than the stock headers. But most of the discussion seems to center around a NA 911.
In BA's book, it actually alludes to the use of post-86 factory header as they are actually good. So for all 930 experts - what's your opinion? Is it worth spending $$$ to upgrade the factory header from a post-86 car to GHL/B&B/ ??? thanks...
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Hi Patrick - replacing the stock headers on a 930 with a GHL or B&B setup is a great upgrade. The 86-89 headers are a good upgrade for the older cars that use thermal reactors (pre 78 I believe), but your 87 930 will gain quite a bit of low end responsiveness and quicker turbo spool from after market headers. I have GHL headers on my 86 930 and the difference was quite noticeable.
Bill |
Thanks for the input... and darn - thought i can save those $$$ for something else
Patrick,
Headers will make you a happy man. I run B&B, GHL is also a good set. You should be able to deal a bit with your supplier, the starting price was $2,050.00 and I got it down to $1,650.00 with the install Kit. (Pelican sells them) Takes" Bling" to run in the fast lane!! Good luck!
"Never go faster than you can stop" 85 - 930 (750hp) Norwood motec 3.5 twin turbo |
Re: Favourite Subject - Headers...
Thank you for your time, |
Navin Johnson
here are some nice headers.... hope you dont need heat though.
They are by BB but are special order.
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
