Interesting! Those are good reference points as well. Probably need to cut access holes inside the passenger compartment to weld the backside of tube. If could find the correct size tubing I could sleeve both sides. |
http://forums.pelicanparts.com/uploa...1761520059.jpg http://forums.pelicanparts.com/uploa...1761520078.jpg http://forums.pelicanparts.com/uploa...1761520100.jpg |
Maybe I missed something. Is there any question still to answer from my side regarding torsion tube?
j911brick. Thank you for the photos! That install looks good! Is that the jig for the adapter brackets, or did you use them when swapping tubes?
Ok, wow. I looked at some of the photos on Gruppe 9 You did a lot of work! I may have more questions.
Thanks James! I think I will be calling you. I'll. Send you a pm in the next week. |
| All times are GMT -8. The time now is 04:38 PM. |
