-   -   Adapter kit for 930 turbo trailing arms. (http://forums.pelicanparts.com/porsche-911-technical-forum/989388-adapter-kit-930-turbo-trailing-arms.html)
Turbo_pro 03-03-2018 02:30 PM
Back in the day, these kits were pretty common.
Weld on brackets to convert a 74-86 911 (2.7, SC/Carrera) torque tube for installation of 930 turbo trailing arms.
Any idea who might be selling the kit now?
Geneman 03-03-2018 04:00 PM
Zuffenhaus in NC has some beautiful adaptors and kit for this. Cannot remember what town... it's about 20 mi south east of charlotte
Mahler9th 03-03-2018 04:13 PM
John James Racing:
Products – John James Racing
Turbo_pro 03-03-2018 07:36 PM
This is it. Thank you
https://www.zuffenhaus.us/2016/08/12/msrsr-update-rsr-trailing-arm-mounts/
http://forums.pelicanparts.com/uploa...1520134541.jpg
Turbo_pro 03-08-2018 02:21 PM
Aase Sales
(740) 503-3651
Fax: (740) 965-3007
5064 Red Bank Rd.
Galena, Ohio 43021
http://forums.pelicanparts.com/uploa...1520547606.jpg
http://forums.pelicanparts.com/uploa...1520547898.jpg
j911brick 09-20-2024 10:28 AM
Time to resurrect this thread.
I need these brackets for 87-89. I bought the ones from Patrick Racing but they only really work on 86 or earlier.
gled49 09-20-2024 11:19 AM
Post #4 shows G50 installation.
j911brick 09-20-2024 11:30 AM
But they would be different brackets or at least highly modified, and would need a jig to get the location of the holes correct.
Evan Fullerton 09-20-2024 11:57 AM
Nobody makes anything off the shelf for a G50. I bought the John James 935 camber boxes and modified to fit. I was not happy with the quality. If I were to do it again I would design my own and have them laser cut.
j911brick 09-20-2024 12:13 PM
I'm actually considering that but need a way to jog it up so I get the holes in the right place.
Krieger914 10-23-2025 09:47 AM
How hard is it to properly align Aase brackets?
j911brick 10-23-2025 11:07 AM
I have some brackets available that I couldn't use. I would recommend engineering jigs in CAD and 3d printing.
proffighter 10-24-2025 05:15 AM
I have a 930 Torsion tube left over and would sell it... Unfortunately I am in Switzerland, not sure if it's worth to send to the US :confused:
j911brick 10-24-2025 11:14 AM
I can also tell you: depending on your engine/transmission configuration, the torsion tube won't be your only problem.
Geneman 10-25-2025 10:02 AM
THe Zuffenhaus boys were in Monroe NC....SE of Charlotte.. They have been shut and closed for business for years now.
Krieger914 10-25-2025 11:37 AM
That is something cannot do. My version of CAD is Cardboard Aided Design, where I make the part out of cardboard first and then transfer that to steel. :)
Krieger914 10-25-2025 11:45 AM
I have access to a 930 torsion tube. It's still attached to the rear floor section though. Is this a better way to do this? Do I get a big hole saw to get that tube off the rear body section?
mepstein 10-25-2025 12:23 PM
We just did this on an SC. Bought the brackets from PMS (they need work to make fit) and welded them on. We are going to make our own brackets for future installs.
Krieger914 10-25-2025 01:18 PM
Mark, what did it take to align these. I spoke with a guy at PMS and he told me they use a celette bench...
j911brick 10-25-2025 02:56 PM
Try freecad.com
j911brick 10-25-2025 03:01 PM
If you can get a 930 torsion tube that is a better place to start. You can splice it into the old tube pretty easily. You just have to get the angle of the trans mounts right.
Krieger914 10-25-2025 09:45 PM
Interesting! Those are good reference points as well. Probably need to cut access holes inside the passenger compartment to weld the backside of tube. If could find the correct size tubing I could sleeve both sides.
j911brick 10-26-2025 08:47 AM
If you cut it in the right place you can you use the leftover material to make sleeves. In my case I just removed and replaced the rear seat pans. Are you on Facebook? I can probably get pictures when I take the pans out again.
j911brick 10-26-2025 04:08 PM
http://forums.pelicanparts.com/uploa...1761520034.jpg
http://forums.pelicanparts.com/uploa...1761520059.jpg
http://forums.pelicanparts.com/uploa...1761520078.jpg
http://forums.pelicanparts.com/uploa...1761520100.jpg
proffighter 10-27-2025 06:05 AM
Maybe I missed something. Is there any question still to answer from my side regarding torsion tube?
Krieger914 10-27-2025 07:37 AM
Thank you. I do not have any questions regarding the torsion tube you have.
Krieger914 10-27-2025 08:03 AM
j911brick. Thank you for the photos! That install looks good! Is that the jig for the adapter brackets, or did you use them when swapping tubes?
j911brick 10-27-2025 08:34 AM
The jig is to line up the adapters. More info on my Facebook page. But this is for a G50 torque tube. I also have another pelican page with what I went through.
Krieger914 10-27-2025 11:16 AM
Ok, wow. I looked at some of the photos on Gruppe 9 You did a lot of work! I may have more questions. ��
j911brick 10-27-2025 03:48 PM
You should probably call me.
j911brick 10-27-2025 04:09 PM
https://forums.pelicanparts.com/porsche-911-technical-forum/1168629-930-trailing-arms-g50.html
Krieger914 10-27-2025 09:49 PM
Thanks James! I think I will be calling you. I'll. Send you a pm in the next week.
