But OK, I must admit, your obove solution is a sure installation, so when you pull the cable it stays in place. Credit for that SmileWavy |
I have one now and the voltage reading is inconsistent. It reads low after being.plugged in for a while. Unplug it then Plug it back in and it’s ok... for a while then low again. Bought another and same thing. |
Here ya go. All measurements are in mm. http://forums.pelicanparts.com/uploa...1521688293.jpg http://forums.pelicanparts.com/uploa...1521688309.jpg |
Thanks, Frank |
you cn even find some with cupholder function. |
Good job on printing these. I'd be interested in buying a couple of these if you decide to sell them in the future. Stay well.
Looking good!
Hey dad911, care to share the CAD file? I would love to print one of these!
Chris |
Lighter sleeve.
Would love to buy one also
Has anyone else installed this? Seems pretty straightforward and could be a good solution, although I am hesitant to give up the vintage look of the original unit. Mine doesn’t appear to be currently functioning though- the plug-in voltmeters that some have linked doesn’t fit correctly and even holding it in by hand I can’t get it to work. I’ve checked the fuses and I recently cleaned the fuse panel and dash ground. Maybe I’ll just replace the lighter and use the plug in type.
Here’s the link on US Amazon (other link is the Canadian store): MICTUNING MICUV2USBRED2 4.2A Dual Port USB Charger with Voltmeter 12-24V Red LED Digital Display Universal for Car Boat Motorcycle https://www.amazon.com/dp/B01M7V1ME1/ref=cm_sw_r_cp_api_W1UpBb30JGK69 Quote:
https://www.amazon.com/RAVPower-Adapter-iSmart-Charging-iPhone/dp/B071FHZRQN Brgds Alex |
I hacked my old cigarette lighter and used the retaining ring to take up the slack
| All times are GMT -8. The time now is 08:09 AM. |
