breather hoses for emission system - source?
I'm trying piece together the emission system for a 1970 911S. I have everything except the two hoses that terminate in the engine bay. The diagram for the system lists these as 12x2.5mm (1500 and 1620mm long). Part number is apparently N-020-362-1-OEM. Pelican has these listed as no longer available.
Anyone have a source for these hoses?
Old 02-17-2022, 11:41 AM
https://*********************.com/911-912-65-73-/Fuel-Tank/Fuel-Tank-Breather-Hose-12mm-x-17mm-70-91-p31289.html
Old 03-01-2022, 07:18 AM
Another source would be Bel Metric.
Old 03-01-2022, 05:29 PM
Bel Metric appears to have it. Thanks!
Old 03-07-2022, 07:37 AM
Eng-o-neer
Tremelune's Avatar
What is the purpose of these hoses? I'd love to get rid of them...
Old 03-08-2022, 11:04 AM
HarryD's Avatar
Keeps gasoline vapors from filling your passenger compartment and helps to recapture your fuel.
Why do you want to delete? Weight savings are pretty minimal. Going on a personal diet for most of us would be more effective.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 03-08-2022, 11:26 AM
Eng-o-neer
Tremelune's Avatar
Simplicity. Mine are hard and currently not connected to anything as it is. There's gotta be a better way to prevent vapors inside the cabin than all this:
Old 03-08-2022, 11:33 AM
HarryD's Avatar
Check out this thread. You can try the 1969 system posted by Grady.
https://forums.pelicanparts.com/porsche-911-technical-forum/584831-fuel-tank-venting-system-question.html
Harry
2020 MB E350 4Matic
Old 03-08-2022, 12:14 PM
Eng-o-neer
Tremelune's Avatar
I don't want to hijack this thread too much, but it sure seems like running a tiny hose from the tank vent line underneath to the rear bumper would pretty much do it...
Old 03-08-2022, 12:45 PM
keep hijacking. :-) Interested in where this goes.
Old 03-08-2022, 01:45 PM
HarryD's Avatar
Your fuel tank is in the front. Why run a long line. Vent to the front of the car.
If it was me, and wanted to minimize the setup, I would do something like the 1969 setup.
Originally Posted by Grady Clay View Post
Here is the 1969 Evaporative Emissions System
© 1969 Dr. Ing. h.c. F. Porsche K.G.
This shows the fuel system for the 911T (pump at rear), #2, 4, 16, 17.
and
the fuel system for MFI 911E & 911S, #3, 4, 7-10, 16-19, 37-42 and more.
(In 1970, the 911T is plumbed as the 911E&S here.)
The ‘tee’ fitting (#44 above) does not show a 3rd connection here.
My recollection is that is the small vent hose to the filler neck.
The outlet goes through a grommet (#47) in the front panel behind the windshield washer reservoir.
It vents between the front bumper and the inner panel.
''' snip ''''
Best,
Grady
Harry
2020 MB E350 4Matic
Old 03-08-2022, 02:09 PM
Eng-o-neer
Tremelune's Avatar
I just mean get rid of all those boxes and hoses. Just vent the tank to atmosphere to handle the pressure difference, and rely on the smell being behind you to solve that issue.
The '69 solution might be 80% of the ideal solution with 20% of the work, so maybe I'm going too far...
Old 03-08-2022, 02:14 PM
HarryD's Avatar
The little box creates a high point in the fume collection system to keep liquid fuel from exiting. I know when I autocross my car, I often see liquid in the lines from fuel sloshing around. You probably want to install the small tank.
FWIW, the smell will mostly occur when the car sits or is being fueled.
Many years ago, I had the old, hard hose fall off the top of the gas tank. The fumes were really heavy in the passenger compartment.
Harry
2020 MB E350 4Matic
Old 03-08-2022, 02:23 PM
