LinkBack Thread Tools Rating: Thread Rating: 7 votes, 4.86 average.
Eng-o-neer
Tremelune's Avatar
I never even thought about venting...It seems like it would be pretty straightforward to route a tube to the fender via the same route as electrical wiring. How big does it need to be?
Old 04-03-2018, 08:08 AM
scumbag
fuel tank vents aren't very large at all. maybe 5-6mm ID.
i'm doing my best to make everything as tidy as i can. no wires/hoses/etc all over all nimbly-pimbly. so if i can do this without a vent, i will delete the nipple on the tank. if i need the vent, i'm going to keep the nipple and vent from there. thus i'm asking before i modify the tank as i don't want to pull/drain/cut/weld/grind/sand/paint/replumb/refill twice.
http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html
IG: @doktor_b
Old 04-03-2018, 09:00 AM
Under the radar
Trackrash's Avatar
Location: Sebastopol, the land of wine and redwoods in The Republic of California.
My gas cap had a small, one mm, hole in it. Worked fine as a vent.
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-03-2018, 09:31 AM
scumbag
but would you use that in the trunk where fuel vapor would eventually get into the cabin? or into whatever you put in your trunk? (like clothes or groceries)
IG: @doktor_b
Old 04-03-2018, 09:49 AM
New-ish 911SC Targa Owner
pampadori's Avatar
low budgets get blown out when you remove the valve covers and broken bolts fall out. Have you looked at the motor much yet?
I was installing my coil on plugs for my ITB/EFI swap when I noticed something in the way of my spark plug socket. It turned out to be the top half of a broken head stud. Found a handful of others broken too. Had to do a full rebuild which was NOT in the original budget. :/
you can EASILY spend $6k - $10k on rebuilding one of these engines.
I hope you don't have such a setback my friend. Godspeed.
P.s. H2O was one of my first shows back in the 90's! couldn't cut it as x edge but still have lots of friends that have managed to maintain. Always respect them for that too.
'83 Targa 300k w/ freshened 3.0 with 930/52 case and ARP and Raceware hardware - AEM Infinity 506, Triumph T595 throttle bodies, B&B headers, Dynomax muff, Fidanza FW, Alum PP
'05 E500 wagon in minty cond
'13 Volvo XC60 (hers)
Old 04-03-2018, 11:12 AM
scumbag
Shaun,
i haven't yet pulled the valve covers. i have new gaskets and hardware and valve lash feeler for when the time comes. i know i'm rolling the dice, but i'm going to pull the valve covers before i put the EFI on. so i'll know how bad it is before too long. with how lucky i've been with the body, i'm about due for a little heartbreak. rest assured i'll be posting the results when the covers come off.
and hell yeah! HxC for life. H2O is super good live. i've been edge for 25 years and vegetarian for 22. no going back now on either. MOF, my wife lists breaking edge up there with marital cardinal sins like cheating. she's afraid of the monster that intoxicated Chris may be. (never drank or did drugs, so it's speculation) it's been a great community to grow up with and has helped mold me into who i am now.
IG: @doktor_b
Old 04-03-2018, 11:22 AM
Under the radar
Trackrash's Avatar
Only if the cap was outside the trunk. My thinking was the center mounted fill would be outside. Maybe I was unclear as to how the filler would be installed.
Gordon
Old 04-03-2018, 11:30 AM
scumbag
understood. i'm not sold on the through-hood filler cap. it's a nice touch, but idk.
i like the simplification of the underhood filler. no long fill neck. no hole in the fender. no hole in the hood. microscopic weight savings. in my mind, simpler is almost always better. (ITBs notwithstanding)
IG: @doktor_b
Old 04-03-2018, 11:34 AM
Registered Minimalist
75 911s's Avatar
I like the idea of the hidden fill too. Hmmm car is in paint currently..wouldn't be that hard to delete the filler cap. :-)
Duane
http://forums.pelicanparts.com/porsche-911-technical-forum/878569-born-75-me-my-new-911s.html
Old 04-03-2018, 12:25 PM
Kamran's Avatar
Location: sothern California, Aliso Viejo, Orange County
Send a message via AIM to Kamran Send a message via Yahoo to Kamran
Cant wait to see it after paint, I'm still trying to fix the rust in my 69... :/ Im guessing you went with the standard SC body look because i didn't see any fenders pictured... going to be a beautiful car!!!!
Old 04-03-2018, 12:44 PM
scumbag
I found a solid deal on one. Iíll message you the details.
IG: @doktor_b
Old 04-03-2018, 05:08 PM
scumbag
Mine will be standard SC body for a while. Itíll also likely spend a year or three in epoxy primer while I sort it all out and make decisions.
IG: @doktor_b
Old 04-03-2018, 05:11 PM
scumbag
spent a few more hours last night working on getting the Fenn Lane panel to fit the roof.
i hate body work so hard. totally why my M3 had bolt-on over-fenders. just chop out the old, rivet on the new, and go. easy. i've already got twice as much time in just the roof of the 911 than i did in the entire widebody conversion of my M3.
gotta stop by Harbor Freight omw home tonight to grab some big magnets and then i'm hoping i'll be able to get the panel fit finalized tonight and glue it tomorrow night.
#fingerscrossed
#maytheForcebewithme
IG: @doktor_b
Old 04-05-2018, 03:56 AM
I'm late to this thread, but once I saw the car and the H2O banner I knew this would be good. Excellent work so far! Keep it up!
youtube.com/bennyobscene
Old 04-05-2018, 05:42 AM
If you go back to white, you might want to consider keeping the rims as is......makes for a nice contrast. I built this many years ago, wish I still had her It was a '78sc with a '85 3.2, set up for track duty.
'04 GT3 - Track Weapon
'88 Club Sport - 1 of 28 in the US
'00 Boxster - Daily Duty
'77 Yamaha RD 400
Old 04-05-2018, 02:43 PM
scumbag
you should see the American Straight Edge banner on the facing wall. i'll try to live up to the hype. my only caveat is that i build drivers, not show cars. this car will be built in my garage and it will retain most of the flaws, just like i keep all my scars.
#DFYR
thanks for the pic! i actually have given very little thought to the future of the Fuchs. i have a set of CCW Classics (race) in the basement that need refurbishment that were originally destined for this car. but wheels are so far down the line, i'm just not going to worry about them until after i can drive it out of the garage.
in other news, i had a friend (with a lot more body work experience) come over last night and look at the sunroof delete. he thinks it'll be fine how it is and is planning to come over saturday and help me get it glued in. i'll probably be up early saturday tinkering with the fit before he comes over. i realize a lot of shaping can be done with a grinder, sanding, and (FML) filler. but i'm doing my best to minimize the use of filler on this project.
my feedback so far on the Fenn Lane panel is that a spot-welder would certainly be the easiest way to permanently affix the panel. my current setup of tension rods pushing up and magnets pushing down (to 'clamp' the flange to the roof) is alchemy at very minimum...and will get the bump to sorcery if it comes out ok.
I AM NOT A BODY GUY.
pics of the 5hit5how.
i wasn't happy with the pressure at the flange, so i decided to push down as well as up.
also this
IG: @doktor_b
Old 04-06-2018, 03:59 AM
Nothing to offer but moral support and well wishes. Came over from the bimmer world to lurk as your journey is worth the read, (or as Miley says "It's the climb"!....a 52 year old just shouldn't know MC lyrics so keep that between us.).
I will be here to the end and whatever you end up with will be awesome as it has your heart and soul, and blood and checkbook in it!!!
Great progress thus far!
Old 04-06-2018, 04:35 AM
scumbag
thank you. and no judgement on musical choices ever...unless ska music. ska alone is inexcusable.
so i went and made my questionable decision making permanent.
from further than 3', the roof looks pretty darn good. from 3' and closer, you see that i have some work cut out for me to make this patch invisible.
here's some detail shots.
rear seam from right side
and from the left
i'm super stoked on the rear seam. it should be 'easy' to blend in with a smidge of filler and minimal shaping.
the rest will require a bit more finesse to get right.
here's the left side seam from front.
front seam from left
front seam from right
right seam from front
right seam from rear
as you can see, that front right corner was the least cooperative seam. i'm going to trim out the pushed out panel bond from the front seam so the filler sits right on metal and has the best bond it can. and then clean everything again and do a little block sanding to see just how far out of shape i am. i think it's pretty close, but i'm still not a body guy.
IG: @doktor_b
Old 04-08-2018, 11:26 AM
Science is not optional
rbogh901's Avatar
I have been looking at doing this for a while too. Wonder what the options are. Not through Hood. And, yes, don't really want to trap any gas fumes in the frunk. Need 2 vent to outside the car if a vent is needed.
PCA member since 1993
Old 04-08-2018, 12:45 PM
75 911s's Avatar
Was thinking a bit more about this. I think cap off the fill neck of the tank itself, and use any of the after market conversions for below the hood fill. There's one that replaces the fuel level sender with a fill neck, and another that welds in. I would leave the expansion tank as is. On the fill tube, place a small vent line that vents to near the expansion tank.
Chris,
The sunroof fill looks great man! I think you'll find that you did pretty darn good, all things considered.
Duane
Old 04-08-2018, 03:33 PM
