Red face Any worry here?
Hi Pelicans - I was crawling around under the car, and I got a look at my very new (<1 year old) tie rod ends. Any thoughts on this?
Thanks, Pelicans!
Old 03-05-2018, 06:46 PM
ROW '78 911 Targa
timmy2's Avatar
Hard to see the ball joints, but your tie rod ends are rusty.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, Bitz kit EFI.
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 03-05-2018, 07:05 PM
Banned
Check the boot around the tie-rod and make sure that it isn't split and send grease out. Like Timmy said though, if your ball joints were what was replaced then you're prob just in need of some tie-rod ends now.
Old 03-05-2018, 07:19 PM
old man neri's Avatar
If there is no play or torn boot I wouldn't worry about it. What I would worry about is getting those off when the time comes. I'm not sure how you could get some anti-seize on there without throwing your alignment off.
Old 03-05-2018, 07:41 PM
I've just outed myself as a relative noob...
Old 03-06-2018, 07:37 AM
devalued member
juanbenae's Avatar
you can get metal etch that you spray after diluting that will remove surface rust enough to repaint to prevent further rusting. if you really wanna get at it paint with POR15 paint.
jasco makes a etch ive used a ton over the years and it works great at rust removal. mask everything but the tierod end, including the threads and repaint. good as new.
75S slick-lid webered, early n spicy 3.oL hotrod wanna be
07.5 2500HD GM Diesel 4x/93 tuff-gong 4.oL YJ Wrangler
08 DRZ400SM+FCR Mikuni
78SC PRC Spec911(sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ
Old 03-06-2018, 07:50 AM
76 911S Targa
The functional parts of the tie rod ends and ball joints are packed in grease. Exterior surface rust has no structural effect. Spray it with rustoleum to prevent further surface oxidation, maybe a nice fluorescent orange.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Trombone Oil Cooler, Turbo Tie Rods.
Old 03-06-2018, 10:53 AM
Shoot me a PM if you want to swing by to check them out. I'm only about 5 minutes from Mt. Vernon. It just looks like surface rust and OK. But it also looks like the nut is not down far enough.
If you need a great wrench, check out RPM in Lorton.
1969 911E
2002 996 Cabrio
1995 993 Carrera 4 SOLD
Old 03-06-2018, 11:07 AM
faverymi's Avatar
URO?
Lemforder?
Porsche?
RSA Frankenporch Helga
Carrera MonstaBoxstah
Old 03-07-2018, 06:07 PM
Lemforder. Purchased Feb 2017.
Originally Posted by faverymi View Post
URO?
Lemforder?
Porsche?
Old 03-07-2018, 06:11 PM
After I completed the suspension, but before I drove it, I had Intersport in McLean check the torque on every nut and bolt, so Iím pretty confident itís buttoned up.
Always happy to meet a fellow Pelican tho! Letís catch up soon. Look for a PM. Thanks!
Old 03-07-2018, 06:14 PM
Send a message via Skype™ to sus911
Brake fluid?
cheers,
Phil
84 ROW Carrera (guards red), A/C delete, Fuchs 7 + 8 x 16, Koni Adj. F+R, sway bars 20F 22R. turbo tie rods, Strut brace, brake cooling kit, C/F Recaro GT3 copies.
Old 03-08-2018, 02:32 PM
My vote is condensation in your garage.
Old 03-08-2018, 03:04 PM
