Originally Posted by universeman View Post
Wow HarryD, he did a great job on yours. Fits like it should, perfectly. Mine's a little less perfect.
Universeman and I are both in Austin and have been sharing our Targa top woes. Will take a look at my clips and see how they look.
It's been quite a frustrating process to-date.
Old 03-08-2018, 12:31 PM
HarryD's Avatar
Originally Posted by pampadori View Post
I wanted to check with others that know these things. My targa top is noisy on the passenger side front. above 70mph it gets pretty loud. When the top is on the car, you can see that the vinyl is lifted slightly at one of the folding seams. it doesn't lay completely flat like it probably should. Is this fixed by having a tighter-fitting top vinyl or does it need something else? will a new top vinyl offer some improvement at all?
From looking at it it doesn't seem like there is anything besides the tension of the vinyl to pull it down tight and straight so i'm ready to spend the $200 on a top cover but not ready to spend $3000 to have it completely rebuilt.
Check Dans Website. Full rebuild is $1400. If you need new seals or something is broken that would be extra. Well worth the price.
If you want to go it alone, you can read lots of threads here to see if you want to proceed. This is an interesting one:
Targa Top Rebuild
Harry
1973.5 911T Targa - "Smokey"
2003 BMW Z4 3.0i
2009 MB C300
Old 03-08-2018, 08:18 PM
