-   -   Sorry - Another 'What's this wire?' Question. (http://forums.pelicanparts.com/porsche-911-technical-forum/989841-sorry-another-whats-wire-question.html)
Munky King 03-07-2018 04:10 PM
I've just taken my steering wheel off to get to the ignition so I can pull it out.
The bottom cover of the steering wheel cover had to come off as well - three screws, and suddenly I'm presented with a wire, I'm not sure where it came from.
Car is a 1975 ('74 build) 911s.
This is the wire:
http://forums.pelicanparts.com/uploa...1520467661.JPG
It looks like it may have been behind the side screw that held the bottom steering column cover on. I can't check though as my cars electrics are a mess!
I've tried looking at my wiring diagram, but there are a few brown wires on there to choose from :D
Any and all (well most) input appreciated!
timmy2 03-07-2018 04:31 PM
Likely ground for the turn signal/hi/low beam switch. Can you follow it back to it’s source?
Brown is ground.
Munky King 03-07-2018 05:20 PM
Thanks for the 'Brown is a ground' comment. At least that might help me find what isn't working until I ground it out in the future!
So far I've only touched three screws:http://forums.pelicanparts.com/uploa...1520471712.JPG
I wonder if it came from one of these?
This is a closer look at that side:
http://forums.pelicanparts.com/uploa...1520471776.JPG
Following it back is a good option, but if anyone knows where it goes, I would be really grateful. I don't really want to dismantle the dash much more. I'm only as stuck as I am, as I didn't get the right key, when I bought the car from an estate sale (as a project).
Damn theft safety lock mechanisms!
xbmwguy 03-07-2018 06:14 PM
That ground wire goes in between the lower clamshell and the steering column when you reassemble
Munky King 03-07-2018 06:20 PM
Thanks. :D
Does it get crushed on by the screws, or a trapped fit?
Thank again!!! SmileWavy
kees 03-08-2018 03:14 AM
Picture from a 911 1985...probably the same
http://forums.pelicanparts.com/uploa...1520507639.jpg
Munky King 03-08-2018 03:37 AM
Perfect!
Thanks so much everyone!
I know what to do now when I reassemble it all.
Very much appreciated. SmileWavySmileWavySmileWavy
xbmwguy 03-08-2018 03:39 AM
It goes where kees shows in the picture, however, it is “sandwiched “ between the plastic clamshell and column
sugarwood 03-08-2018 04:52 AM
Here is another photo that is more clear.
Bottom right screw
http://i59.tinypic.com/23sxfub.jpg
Munky King 03-08-2018 07:04 PM
Thanks everyone for the detail and taking the time to post up pictures.
It's a great help. :)
So this weekend, I'm going to try to finally get that lock out to get a working key! :D
