LinkBack Thread Tools Rating: Thread Rating: 4 votes, 3.00 average.
Jonny H's Avatar
We are looking at some time in May for production units.
www.classicretrofit.com
Old 04-04-2018, 02:32 PM
SoCalSK8r's Avatar
Oh I can't wait... my car is once again having alternator problems so I'm holding out for this baby.... replacing the alternator was a pain the back...literally, so I'm only looking forward to doing this once more...
Can you provide any estimates on cost?
Old 04-12-2018, 10:46 AM
Jonny H's Avatar
Old 05-22-2018, 12:51 PM
Eng-o-neer
Tremelune's Avatar
Pretty sweet. Is the voltage regulator adjustable at all? It'd be nice to clear 14v at the battery.
Old 05-25-2018, 12:24 PM
Jonny H's Avatar
It is but you're seeing my in dash meter which is 0.3v below the battery voltage. You'll always get some voltage sag on high continuous loads. Drop a feather on the throttle and you're above 14V.
Most 911's struggle to hold 12v with all the toys switched on at idle
Old 05-25-2018, 12:37 PM
Harpo's Avatar
Are these available to purchase yet? What about my external regulator? Will you offer a new alternator wiring harness that will enable me to bypass my external regulator?
Old 07-07-2018, 05:10 PM
Looks like some stock is available.
Upgraded Porsche 911 Alternator
Rutager West
Old 07-07-2018, 06:50 PM
Unless this has something special all you need is to tape off the connection at the external regulator and connect your existing wiring. I just wonder if the existing wires need to be higher capacity.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 07-07-2018, 07:37 PM
ROW '78 911 Targa
timmy2's Avatar
The website (and first post of this thread) recommends to change out to #4 AWG cable from alternator to starter. Also the ground to the case. Especially if you are installing their electric A/C unit.
I’ve built a couple of harnesses upgraded to that size cable for this alternator.
He (Johnny) sent one customer a replacement cable with the new alternator, but no provision to add the second wire (from 14 pin connector) to the crimped B+ connector as original. Could run it on a second lug, I cut off the supplied connector and crimped in the second red wire as per original.
Basically you need to remove the entire engine harness and strip out the original red cable and replace it with the larger gauge one to get it through the engine tin grommet to the starter area. (If you want it to look good)
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 07-07-2018, 10:10 PM
ROW '78 911 Targa
timmy2's Avatar
This is one of them, 3.0 EFI and stand alone ignition going in a ‘71 so just a really basic harness. You can see the routing of the new larger cable.
Dennis
Old 07-07-2018, 10:23 PM
Jonny H's Avatar
Finally got round to writing the install manual. It also has technical details and performance figures.
PDF on this page:
Dennis, nice harness! I agree that making a new harness is the correct way to go and a obvious choice if the engine is out.
When the engine is in the car, it is a bit more of a challenge. Most installers elect to leave the original battery+ wire in place but disconnected(heat shrinked and safe). The 25mm2 cable we provide can then be run separately. On my own car (an SC), I made an extra hole in the engine tin (with rubber grommet) and the grey piece of shroud above the oil cooler. This allowed me to feed the wire into the shroud and route through to the alternator. Next time the engine is out I may be giving you a call!
Old 09-12-2018, 02:49 AM
PDF on this page:
Anything upcoming for the '89 and up 3.6 motors for us transplant guys?
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 09-12-2018, 06:45 AM
ROW '78 911 Targa
timmy2's Avatar
I’m always up for some horse trading.
IIRC you would need a ‘78 CIS harness ?
PDF on this page:
Dennis
Old 09-12-2018, 08:52 AM
Jonny H's Avatar
Oh yeah, in development! Expecting first engineering samples in a few weeks.
Old 09-12-2018, 10:39 AM
Johnny,
Would the upgraded alternator eliminate the need for the higher speed
alternator pulley/bearing and make the single pulley retrofit more appropriate?
Old 09-12-2018, 11:30 AM
Jonny H's Avatar
Johnny,
Almost certainly. Our current 150A unit puts out 75A at idle. We are aiming a bit higher for the 964/993.
(The normal 115A 964/993 unit only manages 40A at idle)
Old 09-12-2018, 02:31 PM
Very looking forward to 964 items.
Old 09-13-2018, 05:24 AM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
3.2-3.3 Serpentine fan belt conversion 1984-89 [9110-03] - $519.00 : Clewett Engineering, The complete solution for ignition & fuel injection
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 01-10-2019, 07:33 AM
(man/dude)
Jonny042's Avatar
I'm in the middle of a ground-up rebuild and would like to (if not actually purchase and install) prepare the car for eventual installation of the 150A alternator and electric AC and future possibilities of heat.
Is the main cable through the tunnel of the car able to sustain the sort of amperage these accessories will draw? Or is it already large enough due to starter demand?
(Edit-) Can't say it enough, thanks to Classic Retrofit for engineering and manufacturing and supporting these quality upgrades!
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 02-14-2019, 08:09 AM
Jonny H's Avatar
As you guessed, the main starter cable from the battery is capable of handling the load. The wire from the starter to the alternator is not. We supply the 150A alternator with a heavy duty cable set that replaces this wire and the ground strap.
See the alternator install manual on this page:
https://www.classicretrofit.com/pages/manuals-and-software
Old 02-14-2019, 09:14 AM
