-   -   Advice needed / storage to start up (http://forums.pelicanparts.com/porsche-911-technical-forum/990219-advice-needed-storage-start-up.html)
Overseas72 03-11-2018 01:49 PM
Hi all , Can the wisdom on this forum advise me on the correct procedure to start my 911 that's been in storage for about 7 months ?
1974 911 2.7 with CIS . The battery was on a tender. I know it will start . I just don't want to damage anything if there is a better step then just turn it over after this long . Thank you in advance
da Vinci Dan 03-11-2018 03:02 PM
Double post? May want to delete the first one.
Brian911T 03-11-2018 03:31 PM
I would disconnect fuel pump and turn it over until you build oil pressure on the gauge. Should be fine after that.
