Cleaning sump screen?
Hi all,
So as per my thread a couple of days ago a leak developed after an oil change. I have a new sump plate kit and silicone gaskets on the way from our host but wanted to clean up the screen also (probably part of my leak problem). See the picture - there is quite a bit of gasket remains on it. Any suggestions on how to get this nice and clean?
Thanks!
Todd
Old 03-12-2018, 08:48 PM
Sorry, picture didn't load on mobile.
Old 03-12-2018, 08:52 PM
Sorry, one more question. I haven't jacked up the car yet to really get a good look at the sump itself, but assume there is residue there as well that should be cleaned. Any suggestions on how to clean that?
Old 03-12-2018, 08:53 PM
Under the radar
Trackrash's Avatar
I used a razor blade. Use it in a scraping motion. Be careful not to scratch the metal.
Gordon
'71 911 Coupe 3,0L outlawed
Old 03-12-2018, 09:22 PM
Since you're so far along here, I'd recommend:
1) tippy-tap the pump screen with a small hammer on a flat surface around the eight holes to get the mating surface dead flat.
2) use a dental pic or something similar, lacquer thinner, & compressed air to get all the silicone chunks out of the screen.
3) before you reassemble, get your fingers up in the motor & scrape out any residual oil & debris, particularly under the distributor where you may find remnants of a Bakelite spacer or more silicone chunks.
4) if you find Bakelite chunks, remove the distributor cap & try to move the shaft up & down. If it moves a quarter inch pull the distributor and replace your now missing Bakelite washer with stainless shims. Cheap insurance to fix now if necessary.
Old 03-12-2018, 10:40 PM
