1988 Carrera
Rear wheel bearing
I just replaced my rear wheel bearing. After the install, the hub is very hard to turn. Every thing has been cleaned and I do not have the axle attached yet. Every thing came out with no problems.
I'm thinking that I have put too much pressure on the hub and thinking of using the slide hammer to back it out just a tad. Lots of threads or removing the bearings but very little about hub install. Any one have any ideas? Car is a 1988 coupe Carrera.
88' Carrera 79' SC gone (lost to Katrina) 75' Targa gone 72'914 gone 72' 914 gone too |
911T '72
How dit you install the hub in the bearing? Did you press it in?
Dennis Good drivers have dead flies on the side windows. (Walter Röhrl) |
If you did not support the inside inner race, the hub will push it out and damage the bearing. try slipping the stub axle in and tighten the nut.
1988 Carrera
I used this tool
1988 Carrera
Thanks John. I'll give that a try.
911T '72
This is how I installed my hub
1988 Carrera
Dennis: I used the same method .
John: I did as you instructed. Turns much easier now .
