Help with 83 911 SC brakes
Good day! I finally swapped out my old calipers for some new PMB rebuilt ones, bled the system 5x all the way around and I am still getting a pedal to the floor. No leaks at any of the lines or bleeder valves, no air bubbles when I bleed the calipers. I had the Master Cylinder empty for at least 6 weeks waiting on the brakes, I am concerned my master has now failed or some internal seals dried up while it was empty. Is there anything I am missing here? I've bled brakes multiple times before and I am confident the issue is not air or poor installation. I can't think of anything else that would create the failure. As far as I know the MC may be original.
thank you so much- jason |
Addendum - Rubber lines are all new
I have a line coming out of the transmission tunnel that is disconnected, would loss of vacuum cause this problem? And where does the line go to? |
guess that's it. bad seals dried out or ripped now when fluid flush with too much pressure.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
I searched and couldn't find the thread(s) that came to mind.
There is a possible issue if the master cylinder piston extends too far into the bore when bleeding the system. IIRC, something about the forward seal can be scratched from the cylinder wall if it is extended too deep.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
911SC Tinkerer
Deeking,
How exactly did you bleed the brakes? Are the calipers on with the bleeder screws pointed up? Are you 100% sure the lines are all tight? I only ask because I had trouble bleeding my brakes on my ‘83 as well and in the end it took 4 complete cycles with a power (pressure) bleeder to really get the pedal feel perfect. This was after the buddy method and the vacuum method at the bleeder. Let us know, -Steve
-'83 911SC Coupe SSIs, Dansk GT3, EFI ITB, Instagram: @ Zinnmetallic_sc |
May need to bench bleed the MC
Thanks all. I did the 2 man method with my father which we have done multiple times before. Pump up brakes, hold pressure, release bleeder, fluid out, retighten bleeder, release brake pressure. Multiple times per caliper multiple times around the car. Lines are tight with zero leaks.
Now that I look at it, my rear caliper bleeders are topside while my fronts the bleeders are down. Are my front calipers reversible - did I get them put on the wrong sides? And this would make the difference? I'm not clear on how bench bleeding MC makes a difference when I never had it out, fluid level was never below 1/2 and I have good pressure and no bubbles from bleeder valves. I do think my vacuum line is off but I believe that had happened prior to all my brake work, my SC has been backdated to carbs would that make a difference? j |
Yep, that's it. I did the same thing on my SC so you're not alone. The right way up will fix it LOL |
shh-the robot is sleeping
Bingo - can’t bleed if valves are down. Air is still caught above.
'88 911 Coupe, 69k miles |
Wow, amazing the difference! Significantly better pedal feel after evacuating that air with bleeders pointed up. Still not hard pedal feel I had before I dove down this hole. Will that improve with pad/caliper break in or do I need to continue bleeding?
j |
The 9 Store
A lot of times they will improve after you drive a bit, bed the pads and then bleed again.
All used parts sold as is. |
