I had the same (or similar) noises when I first purchased my car. I had tightened a couple of time with temporary success.
It turned out that either the incorrect # of shims were installed or the nut was loose because when I took everything apart I noticed that the washers or cap had carved a groove into the keyed protrusion on the fan...actually on the yellow chromate piece that's riveted on the fan. As a result it was not possible to center and tighten the fan properly. Had to get a new one. I'm going from memory here so I hope I'm not totally off with describing the "keyed" protrusion. |
Gee... I like to work on that car! I don't have lots of experience but I like it! Alain |
I just changed my alternator this summer because of a rattle in the alternator. The bearings had worn a slight groove in the shaft and were failing. I ended up replacing the entire alternator. But now other than my Dansk, I have a quiet car.
