-   -   Rear alignment bolt fused to trailing arm. (http://forums.pelicanparts.com/porsche-911-technical-forum/991394-rear-alignment-bolt-fused-trailing-arm.html)
old man neri 03-24-2018 05:13 PM
Originally Posted by bkreigsr (Post 9974238)
TA-DAH.
Thanks all. Combination of soaking - 5 days, turning with a wrench with BFH, and turning while tapping the nut.
Anyone recognize the bolt/nut on the right?
The head is 7/8 inch, and the nut is 11/16th. Notice how much more surface/contact area there is in the shoulder that fits into the swing arm.
New hardware will be here on the 28th from our host. ($62.50 each, for the eccentrics - ouch)
Bill K
Nice work. I was cheap and just reused mine. You will probably have to take a wire brush to the inside of the trailing arm where the bolts slot into.
bkreigsr 03-25-2018 10:36 AM
Moderator - thanks for moving this - I didn't notice the placement until yesterday.
I'm usually the one who shouts back - 'Hey - you're in the wrong forum'.
So does anyone recognize the bolt on the right?
Bill K
SalParadise 03-25-2018 10:58 AM
Bill, that's a sweet 912. Color is awesome.
bkreigsr 03-25-2018 11:43 AM
Thanks Sal.
My 911s are/have been Bahia Red, Peru Red and Guards Red.
So I purposely held out for a color other than RED!!!
It's a fair 10-footer that's been re-sprayed 3 times in three different hues of silver. But, as mentioned, still very presentable.
Bill K
Jim2 03-25-2018 12:11 PM
That bolt is a Welmeister sway bar link adaptor.
bkreigsr 03-25-2018 12:25 PM
Wow, good eye. I didn't know they were eccentric.
Bill K
911pcars 03-25-2018 01:44 PM
Bill K
BTW, unless WM has upgraded the rear hardware, the lower drop link threaded bolt is a relatively puny 5/16" socket head bolt. Probably ok on a relative lighter early 911, but may be compromised on SC/Carerra models..
Tarrett and ER hardware/drop link hardware appear to be 3/8" or metric equiv.
FWIW,
Sherwood
KTL 03-26-2018 06:43 AM
I always felt the same way about that bolt going into the alignment eccentric. As dainty as it seems, the weak link (literally, not a pun) that I have seen is the sliding bracket that attaches the drop link. It breaks at the welds highlighted in red
http://forums.pelicanparts.com/uploa...1522071775.jpg
bkreigsr 03-26-2018 08:29 AM
That's why I got rid of the WM and went back to the factory dogbones.
Bill K
