Braking Activates Front Left Parking Lamp
Facing a reflective window today I noticed that when I depressed the brake pedal my front left parking lamp comes on. I have not done anything to the wiring and the harness is original and unmolested. Any ideas?
Old 03-23-2018, 07:53 PM
Titanium User
Check all the grounds - ones in the front blinkers and rear tail light housings.
Old 03-23-2018, 08:05 PM
newb.
eimkeith's Avatar
I’d clean all the sockets in the left taillight housing.
Sent from my iPhone using Tapatalk Pro
keith
'75 RS/RSR-look | '73 CB750 | '70 TD250B
r gruppe #436
Old 03-24-2018, 05:01 AM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Second on a bad ground being the cause. The brake light is seeking a ground (to complete a circuit) via any available path - in this case, your park light circuit.
1986 Targa Guards Red
2021 MT09 SP
Old 03-24-2018, 05:35 AM
Replace your rear brake light bulbs with correct OE bulbs, seems illogical but it will solve the issue.
Old 03-25-2018, 01:30 AM
Single filament bulb in a double contact hole?
206 637 4071
Old 03-25-2018, 08:54 AM
Thanks everyone. I used steel wool to clean bulb and socket then cleaned both with automotive electrical cleaner spray. At least for the time being it did the trick. When I depress the brake pedal the rear brake lights activate and the front parking lamps do not!
Old 03-26-2018, 05:05 AM
