LinkBack Thread Tools Rating: Thread Rating: 5 votes, 4.40 average.
Old 03-22-2018, 01:37 PM
Old 03-22-2018, 01:38 PM
Old 03-22-2018, 01:39 PM
Old 03-22-2018, 01:40 PM
Old 03-22-2018, 01:41 PM
Old 03-22-2018, 01:43 PM
Old 03-22-2018, 01:45 PM
Old 03-22-2018, 01:46 PM
Old 03-22-2018, 01:49 PM
Uhhhhh,....sex
Old 03-24-2018, 04:16 PM
Eng-o-neer
Tremelune's Avatar
Hoooly cow...Did you know there was this much rust hiding? It looked clean in the first photos!
What are the advantages of the welded-in front strut brace mounts as opposed to using the stock location with the 3 bolts?
Old 03-24-2018, 09:09 PM
Not many could save this car much less transform it, thanks for all the pics!
77 911s
16 981gts
Old 03-25-2018, 03:58 AM
I like the weld in cause your "bracing the body". I think its more rigid in the end, not just bracing the shocks/sturts.
I had no idea there was this kind of rust.
I do not claim to be a metal master, but for real, this has got to be the most body filler I have ever seen used on a car. I would bet there was over 3 gallons used.
Old 03-25-2018, 04:29 AM
Nice work! Dry ice in the floor pans?
Old 03-25-2018, 05:17 AM
Yes sir!
Old 03-25-2018, 05:20 AM
Edoyle's Avatar
That body filler cross section is mind blowing. Great work!
Old 03-25-2018, 07:24 AM
Indeed, it looks more like sheetrock (the bondo..). Wear a mask when you remove it!
Old 03-25-2018, 09:07 AM
Fearless work Jim - with this much cutting and grinding on this build, you should start your own "Project Binky" YouTube channel.
What are you using to drill the spot-welds? It looks like you have lots of experience.
Keep the updates coming, you are an inspiration to the rest of us,
Richard.
RSR Replica - http://forums.pelicanparts.com/porsche-911-technical-forum/472762-rsr-update.html
930 Cab - ex-IA car, 3.4L, 1.2 bar, G50
996 Turbo - X50.
Old 03-25-2018, 11:39 AM
I promised you all I would explain why the builds were changing directions. Iíll give you a little teaser
Old 03-25-2018, 11:44 AM
