michaelw's Avatar
Post Adjusting windows on 87 targa?
Hey guys, I am trying to adjust the drivers side door on my car to eliminate some wind noise at the top of the window where it meets the targa top. It looks like all it needs is for the window to be moved up evenly, less than a milimeter. Problem is, Bentley's only shows 1 screw that allows you to tilt the whole window, hence not evenly move it up. Is this correct? I can't accomplish what I want by just tilting the rear of the window.
Michael
Old 11-03-2001, 05:45 AM
Kevin Stewart's Avatar
Post
You have to take the door panel off there are two allen bolts that you adjust they are about6-7 inches from the bottom i believe they are connected to the window, the front one adjust the fron hight and the rear the rear youll have top adjust both, if you can you need to put some type of bolt lock fluid so it doesnt slip again, make sure you dont tear the plastic behind the door panel if its junk replace it with a trash bag this will keep your door panel from getting water damage
Old 11-03-2001, 04:51 PM
