best way to clean this?
I wasn't sure what would be the best way to thoroughly clean this.
Being that there is plastic on it and some electronics inside... anyone have a suggestion on how to clean the inside and outside to restore it back to new?
Thanks!
1987 Porsche 911 Carrera Coupe
Old 03-26-2018, 07:39 AM
Registered Minimalist
75 911s's Avatar
I used black magic on a similar engine part (off the shelf black trim product) I think it's by mequires. It's specifically formulated for plastics. You can use a toothbrush with a small clean rag to rub it in and clean it up.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 03-26-2018, 08:51 AM
lpsalsaman's Avatar
That's your Air Flow Meter, it's aluminum. I would suggest using some light solvent, you can get it at any auto parts store. However, unlike any other part, since you have an electrical connection just do it by hand with a rag. Making sure your electric port does not get wet with the solvent. Hope this helps!
U.S. Army Retired
85 Targa Guards Red
2018 BMW 530i M-Sport
Personal Quote: "Do whatever makes you feel good"
Old 03-26-2018, 09:01 AM
WD-40 with a rag, toothbrush and q-tips would be a light solvent that is relatively safe to the aluminum and the plastic.
Good luck,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 03-26-2018, 10:43 AM
Counterclockwise?
I just used brake clean, a small brass brush and compressed air.
Rod
1986 Carrera
2001 996TT
Old 03-26-2018, 11:34 AM
ok... so I guess sandblasting is out of the question...
is there any sensor inside that I need to be careful not to touch/break? As the inside has some oily residue that I need to clean off... I don't want to gunk up any sensor.
Old 03-26-2018, 02:46 PM
Through it in the dishwasher
Old 03-26-2018, 06:19 PM
Or throw
Old 03-26-2018, 06:20 PM
I think spraying it lightly with Gunk degreaser and a small household steamer might do the trick?
'84 Carrera Targa (3.0 with SSIs, Webers, DC-19 Cams, MSD) - Sold
Old 03-27-2018, 05:05 AM
Flojo's Avatar
Originally Posted by smokerider View Post
through it in the dishwasher
not !!!
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 03-27-2018, 05:49 AM
Functionista
manbridge 74's Avatar
Wanting to return it to like new appearance will require the stuff they use on bare aluminum (think trailers/RV). It’s a light acid solution that you spray on and wash off. You could first do a test on something similar.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 03-27-2018, 09:28 AM
Air Cooled
Craig_D's Avatar
Good luck,
Dave
This. I've restored many motorcycles and engine bays with WD-40, rags, toothbrush, Q-tips and toothpicks in the corners. Works great and isn't harsh.
'78 911 SC "Blackjack" & '76 914/4 2.0L "The Brat"
'99 Honda VFR800Fi, '98 Honda SuperHawk
'88 Honda Hawk GT, '77 Honda CB750K Cafe
'69 Honda CL350
Old 03-27-2018, 09:41 AM
DanielDudley's Avatar
Vinegar is a light acid solution. Would need to be de greased first.
Old 03-27-2018, 09:44 AM
ptrsbtrs
peter leinberge's Avatar
The auto industry has "wheel acid" in various, diluteable strengths.
Easily applied with a plastic spray bottle, brush lightly, rinse, (no flossing unless it's really bad) viola'!
Works great on Porsche wheels.
Old 03-27-2018, 10:01 AM
