Well done!
Thanks everyone, really appreciate the kind words! Got a few updates from the weekend. First step was insulation. Went with Dynamat Super lite in a few areas and dynaliner. Used Dynapad on the firewall and transmission hump as I figured that's where the majority of noise would come from
http://forums.pelicanparts.com/uploa...1538462541.JPG Then went ahead and installed the charcoal plush carpet from appbiz. Very happy with the results and went on pretty easily. http://forums.pelicanparts.com/uploa...1538462541.JPG http://forums.pelicanparts.com/uploa...1538462541.JPG http://forums.pelicanparts.com/uploa...1538462541.JPG http://forums.pelicanparts.com/uploa...1538462541.JPG http://forums.pelicanparts.com/uploa...1538462541.JPG Placed the rennline tunnel cover as well as the floorboards as well to see how they'd look. Had them in storage for months and was ansty to see what they'd look like! Also placed the decklid with the x-faktory grills just to see how it looks and fits. http://forums.pelicanparts.com/uploa...1538462927.JPG http://forums.pelicanparts.com/uploa...1538462927.JPG |
Today I also received my set of yellow "French" lenses for the headlights. Mounted them on the projector assemblies and placed it on the fender to see how it looks. I like the look, still have to paint the color matched headlight rings. Not sure if to go with European tail light lenses as well to match, what do you guys think?
http://forums.pelicanparts.com/uploa...1538463203.JPG http://forums.pelicanparts.com/uploa...1538463203.JPG I forgot I had also taken a few pictures of the dash pieces in brushed aluminum in case anyone was interested in seeing what they looked like. http://forums.pelicanparts.com/uploa...1538463203.JPG http://forums.pelicanparts.com/uploa...1538463203.JPG http://forums.pelicanparts.com/uploa...1538463203.JPG http://forums.pelicanparts.com/uploa...1538463203.JPG I've had the headliner hanging for a few days to remove some of the creases it had when I received it. I'm hoping to be able to get started on that next as I already have the sunroof motor and the guide tubes wired and installed. Headliner has me a bit worried but we'll see how it goes. I'm also expecting my seats and other interior panels back from the upholstery shop this week as well. |
got those plates. look great, thanks. SmileWavy
where/who did that dash? my project just has a vinyl dash.
my 85 has full leather and the dash looks similar. here is what will go with those plates on my project. have reverted the 85 to stock since this pic. http://forums.pelicanparts.com/uploa...1538674786.jpg |
A bold project AA. Work looks crispy-clean. Nicely done.
Stunning work, sir! I especially like the plush carpeting--I'm about to do the same to my '85. What year kit did you get?
LOL!!! You crack me up aaguiar27....
"I thought I would start a build thread of my 1985 Carrera that I have plans to do a light restoration on." Takes apart the ENTIRE car and strips it down to bare metal.... If this is a 'light' restoration, I can't imagine what a 'FULL' restoration would be!!! ;p |
Loving everything you’re doing. We have similar tastes!
Wow! I’m totally impressed!
Congrats |
Some updates from this past week. The headliner was really not so bad after all. Only took a truck load of binder clips and some 3M 08001 adhesive. The upholsterer gave me a few extra yards of the black vinyl used on the dash to cover the A and B pillars. Used some 1/8 thick dynaliner to recreate the factory padding underneath the trimming.
I should have left the headliner clipped on and stretched overnight before gluing as it seemed to stretch the day after with the heat. It's not so bad that its sagging or wrinkling but it isn't as taught as I would've liked. Hopefully the visor brackets and the window seals bring it in a bit more. Does anybody know which screws are used to hold the visor brackets in place? I can't remember and don't want to use sheet metal screws as I doubt thats what the factory did. http://forums.pelicanparts.com/uploa...1539114745.JPG http://forums.pelicanparts.com/uploa...1539114745.JPG http://forums.pelicanparts.com/uploa...1539114745.JPG http://forums.pelicanparts.com/uploa...1539114745.JPG And the much anticipated seats made it back from the upholsterer as well! Very happy with the outcome. The pictures are not accurate to the color. The actual color is bordeaux which is much darker. Went ahead and finished the last bits of the interior. All that's missing is the sunroof headliner and the seat belts. Eventually I'll cut out the hole for the shifter and permanently mount the pedals. Also put led floor lights operated by the door jam switch and wired/installed the wipers. http://forums.pelicanparts.com/uploa...1539117260.jpg http://forums.pelicanparts.com/uploa...1539117260.jpg http://forums.pelicanparts.com/uploa...1539117260.jpg These are the floor accent lights I mentioned taken in the dark. http://forums.pelicanparts.com/uploa...1539115801.JPG All the pictures make the seats much more red than they are. This picture is probably the most accurate example of the color I have been able to take. http://forums.pelicanparts.com/uploa...1539115801.jpg Bonus Oslo pic http://forums.pelicanparts.com/uploa...1539116593.jpg Next steps would be to cosmetically refresh the engine, possibly replace the clutch, install the glass and doors, figure out how what to do finally with the AC, as well as rebuild and install the brake calipers. Not sure which to tackle first honestly as it doesn't seem to matter which I do first. Any suggestions? |
I took my dash to a local shop, but they did not want to even try. but I have time... PS. that interior is now totally stock. all of those bits will go into the 78 930 with your dash plates. :D keep up the great work. |
PS. I have an older pair of similar Recaro in cloth. will have them recovered.
The aluminum pieces should look great with the dash plates! What color were you thinking for the seats/interior on the 78? |
aaguiar27,
did you put any insulation under headliner? if yes, can you post some photos :) my next job on my 1986 after paint is corrected Thanks Stan |
The only insulation I put on the roof, for now, is the spray on ceramic insulation from lizard skin and three 4 in x 4 inch squares of dynamite. I wanted to put on a layer dynaliner foam insulation but it wouldn’t stick due to the rough texture of the lizard skin. I might try to stick it on in the future with thicker adhesive if there’s too much noise coming in from the roof. I checked and I should be able to from the zipper in the back. Unfortunately I don’t have any pictures of that, but really not much to see honestly. Sent from my iPhone using Tapatalk |
https://uploads.tapatalk-cdn.com/201...6be2e7bed6.jpghttps://uploads.tapatalk-cdn.com/201...9c8acb6151.jpg
Wrapped up the Clifford 5606x alarm installation tonight. Maybe not the best location in terms of security but I’m hoping to add some other theft deterrents as well. The alarm’s main function anyway would be to provide keyless entry with a little extra security. Didn’t come with instructions but after a long search I finally found someone who posted the detailed instructions from the viper version of the same alarm. |
Got a good amount of things done tonight. Got a pair of 993 quarter window seals in and installed the quarter windows.
http://forums.pelicanparts.com/uploa...1539669147.JPG http://forums.pelicanparts.com/uploa...1539669147.JPG Also, test fit the sunroof and fitted the newly painted guide rails and wind deflector. Over the weekend I filled the imperfections in the shifter housing with filler. Finished sanding, priming, and painted it today then reassembled the wevo shifter. http://forums.pelicanparts.com/uploa...1539669873.JPG http://forums.pelicanparts.com/uploa...1539669873.JPG http://forums.pelicanparts.com/uploa...1539669873.JPG http://forums.pelicanparts.com/uploa...1539669873.JPG |
| All times are GMT -8. The time now is 08:34 AM. |
