-   -   When bleeding brakes and the new fluid is the same colour (http://forums.pelicanparts.com/porsche-911-technical-forum/992004-when-bleeding-brakes-new-fluid-same-colour.html)
bcgreen 03-28-2018 04:38 PM
as the old, how do you know when the old fluid is out?
brighton911 03-28-2018 04:52 PM
Sounds like you are changing it fairly frequently (a good practice) and hence no color changes. There really isn't a lot fluid in the lines from master cylinder to the calipers. I remove the old fluid out the master cylinder with a Mityvac and fill it with new then start. So rough guess from past jobs, 4-5 ounces for the rears and 3-4 for the fronts (all per side) to clear the old and run with the new fluid.
tops911 03-28-2018 06:00 PM
I use a quart and it gets all the old out. When i used Super Blue, I would alternate it with the amber colored and a quart would ensure the old was out. plus it's not like you can really save an opened can of brake fluid (so I'm told) so I just used the whole quart.
HarryD 03-28-2018 08:37 PM
I used to measure the volume when I went from Blue to gold (or back). In my 1973 it took about 150 ml to flush the farthest caliper. If you do about a liter equally divided, you will get the old stuff out.
T77911S 03-29-2018 04:31 AM
it depends on what color he started with.
as said,, you need to remove the old fluid from the reservoir before putting in new.
Mike Andrew 03-29-2018 06:32 AM
+1 on cycling an entire quart/liter thru the system. I did this initially and now alternate colors to simplify things.
bcgreen 03-29-2018 07:35 AM
Thanks guys, will go through the whole container.
Sboxin 03-29-2018 09:08 AM
Food color added to brake fluid ??
Another question -
Has anyone ever added food color to the brake fluid to determine old and new fluid ??
I wonder what ATE used to make their fluid blue ??
Regards,
GH85Carrera 03-29-2018 11:30 AM
Originally Posted by Sboxin (Post 9980529)
Another question -
Regards,
Bad idea. The food color is water based. Water and brake fluid are not a good thing. Anything the end user would put in brake fluid is going to adversely affect the fluid performance.
manbridge 74 03-29-2018 12:18 PM
Doing the farthest first (LR on 911) showed me that it takes the most so I do about .35L on it followed by .2L on RR. Then .35 on RF and last bit on LF. I learned this back when Superblue was common. Bet I’ve done thousands of cars...
Sboxin 03-29-2018 01:12 PM
Excellent,
Thank you for the good advice . . . and I thought I came up with a novel idea . . . ha ha.
Regards,
bcgreen 03-29-2018 02:45 PM
How do know you're using 0.35 or 0.2?
manbridge 74 03-29-2018 02:53 PM
Our machines reservoir is clear and has four distinct lines. Pretty easy to eyeball from a distance.
