AEM Infinity efi conversion on 3.0 - wiring questions
I'm buying a car (which hasn't arrived yet) which started life as a 3.0 CIS.. It has been converted to running a 3.2 with EFI.. but I am looking to convert it BACK to 3.0 but with throttle bodies and the AEM Infinity kit courtesy of Rasant Engineering.
I have the 3.0 and the Rasant Kit already... (missing the car). Any ideas as to what I will need to change/modify? I'll be doing it all myself and am not confident changing electrical myself. Thanks in advance. Michael. |
A lot will depend on the condition of the “new” car’s wiring. What year is it?
The Rasant kit has really good instructions to follow. You should strip down your engine harness to remove what isn’t needed. (CIS wiring) As well as make sure it is in good condition. You will need to locate and route wiring for switched power, constant power and the tach signal. When you get the car feel free to PM me to give you some guidance on those items. |
Thanks Denis, you will be hearing from me.
| All times are GMT -8. The time now is 05:30 AM. |
