Formerly known as Syzygy
Canada Kev's Avatar
Originally Posted by DeRRis View Post
Oh and don't forget to order some new handbrake shoes.
Originally Posted by RDM View Post
How often do those wear out? I've never even considered replacing these.
Mine went on one side because the mechanism wouldn't centre itself properly and would allow the pad to make contact with the drum/hat. I guess I drove quite a while with it dragging a bit and wore one of the pads. So I got a bunch of new goodies and rebuilt both sides.
Kevin
Old 03-31-2018, 11:53 AM
1981 911SC
Well I've got the rear calipers off and apart. One of the pistons is just mangled so I'll have to replace that and am hoping a local shop has one so I can be rolling sunday night. The rest looks serviceable. Lines came apart no sweat.
One thing I had unexpected trouble with was the lower 19mm caliper bolt on each side. I could barely get a combo wrench in there for 16th rotation turns - took forever. Now I'm wonder how I've ever going to get in there and crank it back down, much less get my torque wrench in there (NO CHANCE).
Any secret to that nut? A stubby or a low-pro socket needed? What a pain.
Old 03-31-2018, 02:07 PM
Canada Kev's Avatar
No secret that I'm aware of. Yep, it's super tight in there. You might be able to fit in a ratcheting wrench, but I can't remember if I could. For some reason memories of having some issue with that come to mind. Maybe the splines on the ratcheting mechanism were too course to really work well in that space. Sorry, no good advice, just some, "been there, feel your pain", notes of camaraderie. Good luck.
Kevin
Old 03-31-2018, 02:51 PM
old man neri's Avatar
I use a ratcheting wrench. Works beautifully. How tight? It's a big bolt....tight. I've never used a torque wrench. That being said; use a torque wrench on the top one, get a feel for the amount of force needed, and apply the same feel for the bottom.
Pictures of mangled piston?
Old 03-31-2018, 03:07 PM
911T '72
DeRRis's Avatar
Be sure to install the pistons at a 20 degree angle.
Dennis
Good drivers have dead flies on the side windows. (Walter Röhrl)
Old 04-01-2018, 01:19 AM
NutmegCarrera's Avatar
Location: Plymouth Wi. - Spitting distance from Road America
Regarding the front hub dust cap, you may be interested to know that putting a hose clamp around it gives you something to “get behind” and pry it off. Go slowly and a little bit at a time from one side to the other. That way you don’t have to damage it by pounding on it with a mallet.
Old 04-01-2018, 03:52 AM
1981 911SC
Maybe a description would suffice - the pad side lip is jaggedly chunked out in more that 75% of the circumference and there are deep, sharped-edged gouges in multiple places on the piston wall which would definitely do damage to the inner seal. This side of the caliper was in rough shape when I took it apart, but it cleaned up very well and I have little worry about rebuilding with a new caliper.
New rotors and lines are on (after having to drill out one flathead (?!?) rotor retaining screw). I'll rebuild the one complete caliper and install this afternoon so all I have to do to finish the rear is rebuild the last half of the other caliper, bolt on and bleed.
I've been doing this project out in front of the house on the street to get some sunshine and it is wild how many people stop and wax misty-eyed about how they are looking for one or their dad had one or someday they'll do it. Great way to meet the whole neighborhood (including the neighbor's 12 year old who I've manage to enlist in a couple of "projects" already).
Thanks again for all of the replies
Old 04-01-2018, 12:58 PM
1981 911SC
Picked up a new piston from Richard at Sierra Madre Collection in LA who just happened to be heading to the LA Kings game that night at Staples center which also happens to be where I work, so he delivered the part personally same day.
I got everything bolted up this AM and went to bleed the rears and MY GOD was the reservoir dirty. Really fine dark gray silt all over the bottom. I cleaned it up best I could and the flushed the rears until new clear fluid came out. I'm worried that this silt is now all up in the master and wheel calipers, but I also figure if it was that fine and already in there, it is either A) already in there, and/or B) fine enough to get flushed out.
Any thoughts on that?
The brakes work, pedal firmness is about 80% what it was pre project - I imagine I just need to keep bleeding until that improves. don't stop....bahleeedin'... hold on to that pedal feeeellaaaiiiannnn'
Old 04-03-2018, 08:37 AM
Tags
911sc , brake fluid , brakes , fun
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
