H5 humidity absorbent
Is it possible or even necessary to restore the absorbent?
Thanks, Victor |
hi.. nope it is not necessary...;-)
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
How do you do replace the absorbant? I have one light that is fine and the other I cleaned out and within a month it had condensation in it again . I should say also that I live by the ocean where the humidity never really dips below 60%. The heat from the headlight will not dry it out. When I store the car for the winter it clears up to a certain degree.
So how do you replace the absorbant? Or why do I Have this problem with one H-5? Thanks, 86 Carrara |
