-   -   Missing spline for 3.2 Carrera steering wheel ? (http://forums.pelicanparts.com/porsche-911-technical-forum/993026-missing-spline-3-2-carrera-steering-wheel.html)
sugarwood 04-08-2018 07:05 PM
Saw one for sale locally, so I thought it would be fun to refurbish a 3.2 Carrera steering wheel.
I will probably keep it as a spare.
I always wanted to try an upholstery project,
and this seems like a plausible first project.
https://image.prntscr.com/image/IfAs...o9bk1Crjpg.png
The wheel is missing the female spline part.
I suspect it was transferred over to the aftermarket wheel.
Anyone know where I can source the spline part?
https://image.prntscr.com/image/HhUf...jO7ImyNWIw.png
sugarwood 04-20-2018 05:58 PM
For comparison, below shows the splined part that is missing. Does someone make it?
https://image.prntscr.com/image/Tlxf...VmDVNFkQUQ.png
john walker's workshop 04-20-2018 06:01 PM
Never seen one advertised anywhere. I could use one too.
sugarwood 04-20-2018 06:52 PM
I think the owner transferred the spline for use with his aftermarket wheel.
Common to remove the spline and bolt it onto your Momo wheel?
http://forums.pelicanparts.com/porsche-911-technical-forum/312262-momo-steering-wheel-install-illustrated.html
Alex66 04-21-2018 12:43 PM
Looks like this was a wheel with a hub extension which is attached to the hub with 3 allen bolts. The extension part is not available individually so it's going to be difficult to complete the wheel.
Brgds
Alex
GeorgeK 04-21-2018 01:09 PM
What Alex said above. You can swap a std non extended hub on it by drilling out the 4 rivets.
sugarwood 04-21-2018 04:48 PM
If you drill out the 4 rivets, how do you re-attach a standard hub (with spline)?
Are standard hubs commonly sold?
GeorgeK 04-21-2018 11:08 PM
You try and find a std non extended hub froma a worn out wheel.
Hubs, std or extended are not available as spare parts from Porsche.
911 Rod 04-22-2018 11:30 AM
If you could buy the hub it would be nice as there are so many 924/928/944 wheels out there that no one wants.
sugarwood 04-24-2018 03:17 AM
I'm not sure I understand your logic.
What does this have to do with 924/928/944 steering wheels?
Dpmulvan 04-24-2018 04:46 AM
I might have an extra one, give me a day or so.
John McM 04-24-2018 05:06 AM
I sold a 1982 928 four spoke wheel to a SC owner. The wheel fitted his car, so they must be swappable.
911 Rod 04-24-2018 06:13 AM
First I've ever heard of this.
sugarwood 04-29-2018 09:46 AM
Big thanks to SWS911 for sending me a regular steering wheel crush tube hub with spline.
https://image.prntscr.com/image/NvjU...Lv1k_1_gOQ.png
I'll swap this one onto the wheel
Just need to figure out the nest method to remove those rivet heads.
Then get 4 high strength bolts and use red Loctite
https://image.prntscr.com/image/-d6j...IaKh5KV6zg.png
Outlaw_singer 04-29-2018 10:32 AM
That hub fits a 911? I'd love to know more about that...
sugarwood 04-29-2018 12:00 PM
I will remove my current wheel and compare.
What is the clue you are seeing?
sugarwood 04-29-2018 01:55 PM
Good call.
It does not fit.
Diameter is too large
Outlaw_singer 04-29-2018 02:21 PM
Oh i didn't have a real clue. I was just interested in finding out about the make and model since i kind of like how it looked. Nothing more really... :-)
sugarwood 04-29-2018 04:18 PM
Pull back the rubber cover and your car also has that.
