How to remove this AC bracket?
Maybe a dumb question, but it seems this AC bracket has its nut welded to it. So how does one remove it without a mega dissassembly? TIA.
http://forums.pelicanparts.com/uploa...1523300159.JPG |
hi..very easy..use 17mm socket with a flex extension and remove...it will come off right away..
maybe just spray over it wd40..replace it with a nut and washer Ivan |
It’s just an 8 thread...
Bruce |
Tricky to get on it, but just 17mm if I recall.
Thanks for the replies everyone-- I got it removed with a wobbly extension. It is an unusual nut that has a "bushing" of sorts that fits inside the bracket. Hard to explain but it isn't like a regular nut. With the corrosion on it, it was on pretty tight and looked like it was part of the bracket. Not the case, just a good dose of torque and off it came.
| All times are GMT -8. The time now is 09:20 AM. |
