72 911T Fan Shroud Yellow Fiberglass
I need schooled concerning shroud design. I'm trying to source the correct shroud for my '72 2.4 T MFI motor. I see what appears to be two designs. One with a long, grey duct on top of the shroud and the other with a smaller grey duct at the rear of the shroud. The first one has a rectangle cutout in the yellow shroud. The second one does not.
Can someone clarify this and inform me which one is correct for my motor?
thanks
Old 04-10-2018, 07:51 AM
The long grey one is correct for a 72.
Old 04-10-2018, 07:59 AM
OK thanks.
Could someone provide more detail as to why there are different designs?...and the application for both?
thanks
Old 04-10-2018, 08:06 AM
I would rather be driving
jpnovak's Avatar
The long gray is 72. The long yellow is 73. There is a short gray piece that fits over the engine oil cooler. AFIK, the design changed to allow for oil cooler service without removal of the entire intake, induction, fan, shroud parts. In 72 the long gray section is riveted to the shroud and thus not readily removable.
Old 04-10-2018, 08:32 AM
Thanks for that info. Do you know if they can be interchanged between the two years?
Old 04-10-2018, 08:38 AM
jpnovak's Avatar
Physically, yes they can be interchanged. For the 73 you will need to find the missing (in the pic) oil cooler cover section.
Old 04-10-2018, 09:22 AM
Flojo's Avatar
for Service purpose to be able to better adress the oily trinity and the top of the oilcooler, I'd allways upgrade to the later.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 04-10-2018, 09:47 AM
