Could a recent tire rotation cause front end looseness?
Quick question:
I recently put new rear tires on the 911 (245/45/16s) and rotated the fronts (225/50/16s). The car was aligned, but I am noticing that the car feels a bit looser in the front. Noticeably at high speed. But still corners like a champ I'm hoping this is just from the uneven wear of the fronts and it will settle with time. Anything else I should look at? They are uni-directional, and on correctly The pressure is 36R/ 30F No change in brand or size. Thanks! |
Tire Rotation
Alex, forgive me if if i am wrong , you mean you
changed both front tires from left to right, so does that mean one tire is not rotating in the correct direction, or am i incorrect here. regards. |
or maybe he put the 225 up front that were at rear before?
a "loose" front is lacking downforce and weight... did you change anything? did your fuell tank get empty? |
Did you get a print out of the alignment, before & after?
Sorry for the confusion. In addition to putting on new rears tires, I had the front tires rotated. Switched LF and RF tires. No weight or aero changes. I wouldn't say its extremely loose, but just a little more floaty at high speeds
My thoughts about the tire rotation were: If a uni-directional tire that wears more on the outside of the tread, gets switched to the other side (where the worn side is now on the inside), would that make for less "planted" steering? I'm thinking the current toe of the car is causing less tread on the road. Potential "bro-science" here... |
i would check toe with tape measure just to make sure they didnt royally screw it up. But changing tires usually does change the feel of the steering iv found especialy on the 911
My thoughts, worth what you're paying.
You state the front tires are unidirectional. Did you have them removed from the rims and remounted so they continue to rotate in the correct direction, or were they just swapped side-for-side? If they were remounted, then any irregular wear from camber/toe settings will now be on the opposite side of the tread and the amount of tread making firm contact will be diminished. Imagine a FR tire worn a bit more on the outside due to toe settings and steering. Move that tire to the FL, mount it so it rotates in the same direction, and the worn side is now on the inside. This can certainly lead to a different, more squirrely, feel, IMO. |
Did you get the exact same model of tires installed on the rear as the front?
I would Jack each front side up, one at a time, and manually shake the tire at 12 and 6, then at 3 and 9. You might get suprised. This will check your steering rack, ball joints, bearings, tie rods. You can also place a rod, stick crowbar under the raised tire and lift the tire by hand against the suspension. I was in the process of changing to turbo tie rods on my 86 Carrara, and found that the bearings on both sides were loose, one worse than the other, and they had been worked on by PO. And the shocks needed replacing. Also found the brake flex lines to be too stiff. I changed everything out. The car is stored in the winter and has 86,000 mi.
correct rotation with directional tires
This is the correct way with directional tires.
Change them back to the way you had them on the front, until you need to fit new ones regards. http://forums.pelicanparts.com/uploa...1523933907.JPG |
Check your air pressure, they were prob a bit low previously, the combo of the wear and extra pressure will make the rpfrint end feel light. Mine is sensitive to a pound or two...
Check all four pressures. Under inflated rears could cause floaty fronts. Over inflated fronts could cause floaty fronts too.
I've spaced out and done some dumb stuff to my cars late in the day. :confused: I'm guessing it has more to do with your new rears than it does your old, rotated fronts. Probably just have to fool with the pressures to get the right feel all around. (and just to ask a dumb question: are you sure they put the rears on the rears and the fronts the fronts?) |
Check the Toe, if its zero or out, it takes some getting used to.
Jeez, take the easy route:
Swap them back (un rotate them) and see if the floaty feeling goes away. If so you have your answer. 10 minute exercise, depending on how far away from a freeway speed road you live. |
| All times are GMT -8. The time now is 05:46 PM. |
