irl irl is offline
irl's Avatar
Send a message via AIM to irl
What is this cooler- curved 28 row
Was going through some parts I never used to sell on the forum but I donít see this anywhere. Itís 28 rows has all the mounting brackets and connects like the straight version but itís curved. Was originally told it was a European sc model but can find anything about it anywhere.
Eddie from Baltimore
74 911 under construction searching for its new identity
75 911 backdated RSR widebody on its way
71 911T running sweet
63 356 outlaw frustrating purists
Old 04-15-2018, 03:14 PM
irl irl is offline
irl's Avatar
I don’t think so. The inside row is perfectly spread and the outside curvature is perfectly symmetrical.
Old 04-15-2018, 03:45 PM
Just got lucky in the accident.
206 637 4071
Old 04-15-2018, 03:58 PM
Mark Salvetti's Avatar
I would be interested in the bottom mounting bracket and rubber isolators if you are considering selling those bits separately.
Mark
1979 911SC Targa
Old 04-15-2018, 04:41 PM
irl irl is offline
irl's Avatar
Yep, I can see it now. Something tells me this left handed smokeshifter has been flying around here for years. Well unlike the two previous scumbags that I researched that had sold it to unsuspecting members, I will not be. It prob still works but most likely isn’t repairable. Guess I’ll hang it on the garage wall.
Old 04-15-2018, 05:32 PM
911SC Tinkerer
Why don't you have it pressure tested and sell it with the results if they are good?
-'83 911SC Coupe
SSIs, Dansk 2in - 2center-out, Street Fire Ignition, Copper plugs, Instagram: @ Zinnmetallic_sc
Old 04-15-2018, 05:36 PM
irl irl is offline
irl's Avatar
Here is who sold it to me as a rare curved Euro version 4 years ago. Could be the only time I’ve been scammed.
28 row brass cooler - curved euro SC version
Old 04-15-2018, 05:45 PM
Yes, it appears to be a ROW SC cooler. I used to have an 82 ROW RHD that used this cooler. But mine had straight undamaged tubes.
Old 04-15-2018, 06:12 PM
Flojo's Avatar
funny. lloks like PO bent the rear tubes apart to make way for better fitment (?).
+ on that. I have the same. it's heavy but super robust.
the tubes must all be straight.
this model replaced the trombone in 1980 to late 1982. then came the Carrera-alloy-cooler
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
https://www.instagram.com/spadescustomz_/
https://www.instagram.com/911garage_germany/
https://www.facebook.com/911garage
Old 04-16-2018, 05:31 AM
SilverWT's Avatar
Originally Posted by Flojo View Post
fthis model replaced the trombone in 1980 to late 1982. then came the Carrera-alloy-cooler [/img]
Not quite, the 28 row cooler continued into early 3.2 production in 1984.
Both my 1983 SC and 1984 3.2 have the 28 row cooler from new.
Mark
Old 04-16-2018, 10:36 AM
Curvy cooler
Looks like the tank is TIG welded to the core and likely the tubes are soldered in using either soft or hard silver solder. Likely hard solder.
This being my cooler I would cafefully examine the tube solder joints, straighten it, and check the solder joints again. More than one heat exchanger soldered with hard solder has been repaired with soft solder.
Old 04-16-2018, 11:03 AM
Chain fence eating turbo
I can't help but chuckle at the "super rare".....
Sorry about the unfortunate incident, but the seller may have not known better?
I mean, anyone could have told him it was simply bent and he would have removed IMO.
Cory - turbo'd '87 C3.2 Guards/Blk, 3.4, 7.5:1 CR P & C's, soon to be 993SS cams and GSXR 750 ITB's fed by 964 intake, Borg-Warner S366 turbo @ 1.4 bar, Treadstone full bay IC, TiAL F46 WG, HKS 1 1/2" BOV, twin 044 pumps, MegaSquirt 2 (v3.57 board) w/EDIS, Tramont wheels (285's rr, 225's frt), Big Reds frt, 993 rr., tower brace, MOMO wheel
Old 04-16-2018, 11:23 AM
'82 SC TL
canamfan's Avatar
It would be nice to salvage/repair those like Tea Tray mentioned, I've always thought these were a bit of a piece of artful work, BTW I did have them as original equipment on my '84
76'S 1st Porsche white/can/can early rebuild (boo)
'84 Carrera cpe. all blk & stock 340k never a let down (might have been the best1)
'87 Carrera cpe white/blue short flirt
'89 Anniv. sil/linen very pretty miss her
'88 928S4 5spd. blu/blu cmplt.SS exh.chipped lowered
Old 04-16-2018, 11:29 AM
irl irl is offline
irl's Avatar
What is so strange is that it literally is perfectly symmetrical bend. The middle six tubes each three bend out opposite each other. It looks like someone tried to make one with more air flow through the middle. Really didnt think it was in an accident. Funny it may work even better
Old 04-16-2018, 03:18 PM
proporsche's Avatar
Hi Eddie...It will be nice to see the picture from the opening of the bend pipes..it is very possible the previous owner try to put in a fan...
Ivan
1985 911 with original 491 115 miles..790 372km.
Old 04-16-2018, 03:26 PM
irl irl is offline
irl's Avatar
Ill take more pictures but the back looks just like the front, the only pipes spread is the middle row perfectly symmetrical but you couldnt get a fan in there. front and back row just have a nice gradual curve outward.
Old 04-16-2018, 03:33 PM
group911@aol.co's Avatar
I've straightened them before without issue. They are surprisingly flexible.
Thanks,
Bob
group911@aol.com
Old 04-16-2018, 03:38 PM
irl irl is offline
irl's Avatar
What I find strange is the degree of bend on middle row seems a lot more significant than the front and back row bend. if it had been compressed in an accident why are they not all bent to a similar angle with a similar amount of compression?
Old 04-16-2018, 03:39 PM
