khamul02's Avatar
Fuel Distributor RE installation help
Part 2... got the thing on which isn't easy with the engine in.
So now I can guess how the most of the lines hook up but there are a couple that I might be mistaken. Is there an order to the madness to connecting the fuel lines to the distributor? AND or... is it the same as an 80 SC which I have right beside this 81... the fuel lines are different but I guessing the connections are the same?
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 04-16-2018, 02:32 PM
They are not sequential so you have plastic lines just hook up right and left.
Bruce
Old 04-16-2018, 05:16 PM
Fuel lines from fuel distributor.........
This is the normal configuration of the fuel lines connections:
Cylinder #
1..................C
2..................D
3..................E
4..................B
5..................A
6..................F
Tony
Old 04-18-2018, 11:44 AM
khamul02's Avatar
Thank you so much for the info!
Tom Hutchinson
Old 04-18-2018, 12:14 PM
